Home » Eclipse Projects » Remote Application Platform (RAP) » Avoid Composite Background Image from Tiling
Avoid Composite Background Image from Tiling [message #762283] Wed, 07 December 2011 19:57 Go to next message
Ronald So is currently offline Ronald SoFriend
Is there a way to avoid the background image being tiled (show up sequentially multiple times based on the screen size)?
These are the three lines of code I have.
Composite bannerComposite = new Composite(shell, SWT.NONE);
bannerComposite.setBackgroundMode(SWT.INHERIT_DEFAULT);
bannerComposite.setBackgroundImage(IMAGE_BANNER_BG);
From a separate source, people suggest about creating a large background image to avoid this issue.
http://www.sightspecific.com/~mosh/WWW_FAQ/bgfixed.html
Is there a better way to handle that?
Ronald
Re: Avoid Composite Background Image from Tiling [message #763354 is a reply to message #762283] Fri, 09 December 2011 16:17 Go to previous messageGo to next message
Tim Buschtoens is currently offline Tim BuschtoensFriend
Hi Ronald.
Right now there is no way to do that, but there is an open
enhancement-request on bugzilla for such a feature:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=361799
You can set yourself on CC to be notified on any progress for that issue.
Greetings,
Tim
Am 07.12.2011 20:57, schrieb Ronald So:
> Ronald
Re: Avoid Composite Background Image from Tiling [message #763365 is a reply to message #763354] Fri, 09 December 2011 16:40 Go to previous message
Thank you very much!
Re: Avoid Composite Background Image from Tiling [message #763368 is a reply to message #763354] Fri, 09 December 2011 16:40 Go to previous message
Previous Topic:Avoid Composite Background Image from Tiling
Next Topic:Bandwidth constraint
Current Time: Wed Nov 30 08:34:22 GMT 2022
Powered by FUDForum. Page generated in 0.02585 seconds
