Home » Modeling » TMF (Xtext) » grammar mixin(priority of rules)
grammar mixin [message #762079] Wed, 07 December 2011 14:15 Go to next message
Xtexter Mising name is currently offline Xtexter Mising nameFriend
Hello all,
given:
grammar superGrammar with Terminal
Model:elments+=Element*;
Element: 'ct' '(' head = ID ',' text= STRING ')' '.';
grammar subGrammar with superGrammar
Model2: elements2 += Element2*
Element2: Call
Call: 'call' '[' call= Predicate ']' '.';
Predicate: functor = ID '(' Args = ID ')' ;
if this demo would work, my question as i can enter
ct(head1,'text1').
in the first grammar being ct as keyword and colored in red BUT when i enter this in subGrammar:
call[ ct(something)].
The parser complaints because it wants ct(something,'sometext') and not only ct(something) inside call[..] How to understand and manage this priority?
In general does this modularity of mixing grammar have the sense of inheritance and so in OOP or it is just copying whole rules from there to here?
Mokhtar
Re: grammar mixin [message #762119 is a reply to message #762079] Wed, 07 December 2011 15:19 Go to previous messageGo to next message
Meinte Boersma is currently offline Meinte BoersmaFriend
'ct' is a keyword for both grammars, since you defined it in the first one. That means that the 'ct' in "call[ ct(..." isn't matched and consumed by functor=ID from the Predicate of the sub grammar, so it cannot parse the Call. Keywords get priority over "more general" terminals like ID.
Re: grammar mixin [message #762129 is a reply to message #762079] Wed, 07 December 2011 15:37 Go to previous messageGo to next message
Max Goltzsche is currently offline Max GoltzscheFriend
Member
Hey,
As far as I know if you extend a grammar all rules are copied. You can inherit your SubGrammar's Validators, ScopeProvider etc. from superGrammar's Validators, ScopeProvider etc.
But in your example I cannot see how you use your superGrammar in subGrammar. Neither you use Model nor Element.
You can also use / extend your superGrammar's rules but you cannot change its classes because they are already generated.
You should be able to use Element inside call by writing e.g.:
Element2: Call
Call: 'call' '[' call=YourCallFork ']' '.';
YourCallFork: ElementCall | Predicate;
ElementCall: element=Element; // from superGrammar
Predicate: functor = ID '(' Args = ID ')';
If you would like to extend a superGrammar's rule you could write sth like:
import "http://www.superGrammar.org" as superGrammar
Model returns superGrammar::Model:
    elments+=Element*;
Element returns superGrammar::Element:
    Call;
In this case you have to import the superGrammar with a name and override rules by absolute name.
Hope that helps.
regards,
Max
Re: grammar mixin [message #762228 is a reply to message #762129] Wed, 07 December 2011 18:30 Go to previous messageGo to next message
Thank you both, that example was just demo. i did it to express my concern. Now my question is why was the input 'ct'.. not consumed by the rule functor = ID ? as the parsing was inside the Call rule from sub and not inside the Element rule from super grammar?
thankyou danke
Re: grammar mixin [message #762287 is a reply to message #762228] Wed, 07 December 2011 20:06 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
hi,
i guess the problem is that your keywords win over the ID rule so in this case a keyword 'ct' is recognized and not an ID.
=> you have to introduce a datatype rule IDExtended: 'ct'|ID and change the rule to functor=IDExtended
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Previous Topic:refining generated model
Next Topic:Selectively adding actions to Outline popup menu
Current Time: Tue Apr 20 01:13:04 GMT 2021
Powered by FUDForum. Page generated in 0.03448 seconds
