Home » Archived » M2M (model-to-model transformation) » [ATL] Setting details of EAnnotations or maps in general
[ATL] Setting details of EAnnotations or maps in general [message #85340] |
Thu, 26 June 2008 23:17 |
Originally posted by: ttonelli.uwaterloo.ca
I have a transformation whose target metamodel is Ecore. I am trying to add 'details' to an EAnnotation in this way:
from
source : MMsource!SourceType
to
annotation : Ecore!EAnnotation (
details <- a.details->including('name', source.name)
Note that:
- EAnnotation has a "details" feature of type EMap<String, String>;
- EMap is *not* an instance of java.util.Map, it implements java.util.List
- However, EMap has a put(K, V) method
If I try that code, I get an IllegalArgumentException thrown when the details feature is set by reflection (the stack
trace is below).
My questions are:
- am I using the correct idea to set the values on details?
- how is the type system here dealing with EMap? Since I am using "including()" with 2 arguments, I would think that the
compiler treats "details" as a Map (and it should call a put method when performing the transformation). However,
because the runtime object is not really a Map, it seems that the compiler/vm is treating it as a List or Sequence. I
don't understand the VM stack yet, but what gave me this idea was this line:
SEVERE: args = [Sequence {}, 'name', 'PriceCalculatorModel']
which seems to tell that the "empty details" is being treated as the empty sequence, which causes the native operation
to fail.
Thanks for any help,
Thiago
SEVERE: ****** BEGIN Stack Trace
SEVERE: exception:
SEVERE: null
java.lang.IllegalArgumentException
at sun.reflect.GeneratedMethodAccessor110.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:69)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:338)
at org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:326)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:426)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:398)
at org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:42)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:764)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:614)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:880)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1083)
SEVERE: A.main() : ??#24 null
SEVERE: local variables = {self=TestModule : ASMModule}
SEVERE: local stack = []
SEVERE: A.__exec__() : ??#8 null
SEVERE: local variables = {e=TransientLink {rule = 'TestRule', sourceElements = {d = IN!PriceCalculatorModel},
targetElements = {a = OUT!<unnamed>}, variables = {}}, self=TestModule : ASMModule}
SEVERE: A.__applyTestRule(1 : NTransientLink;) : ??#16 25:15-25:51
SEVERE: local variables = {a=OUT!<unnamed>, d=IN!PriceCalculatorModel, link=TransientLink {rule = 'TestRule',
sourceElements = {d = IN!PriceCalculatorModel}, targetElements = {a = OUT!<unnamed>}, variables = {}}, self=TestModule :
ASMModule}
SEVERE: local stack = [OUT!<unnamed>, OUT!<unnamed>, TestModule : ASMModule]
SEVERE: NativeOperation public static org.eclipse.m2m.atl.engine.vm.nativelib.ASMSequence
org.eclipse.m2m.atl.engine.vm.nativelib.ASMSequence.includin g(org.eclipse.m2m.atl.engine.vm.StackFrame,org.eclipse.m2m.a tl.engine.vm.nativelib.ASMSequence,org.eclipse.m2m.atl.engin e.vm.nativelib.ASMOclAny)
SEVERE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow continuation after errors).
SEVERE: null
java.lang.RuntimeException
at org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:195)
at org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:95)
at org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:87)
at org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:74)
Caused by: java.lang.IllegalArgumentException
... 26 more
Re: [ATL] Setting details of EAnnotations or maps in general [message #85413 is a reply to message #85356] |
Fri, 27 June 2008 22:47 |
Hi Brahim,
thanks, it works!
But just to clarify the semantics of this solution, it means that EMap (the details) is actually treated as a List of
EStringToStringMapEntry.
So,
details<-map
is a shortcut for something like:
details<-Set{map}
and then if I want to set several key/value pairs in the details I could do:
details<-Set{map, map2 ,map3}
and create several map entries. It is not the cleanest solution (I have to create several entries), but works fine (I
think it is Ecore's fault to create a map that is actually a list).
Thanks again!
Thiago
Brahim Loukil wrote:
> Hi Thiago,
> Take a look at this example, it will show you how you can add detail to
> an EAnnotation :
> rule Comment2EAnnotation {
> from
> c : UML!Comment
> to
> map : Ecore!EStringToStringMapEntry(
> key <- 'name',
> value <- c.body
> e : Ecore!EAnnotation(
> details<-map
> I enclose the ATL Sample in this post.
> Regards,
> Brahim
> http://www.linkedin.com/in/brlouk
> Thiago Tonelli Bartolomei a écrit :
>> Hi,
>> from
>> to
>> Note that:
>> java.util.List
>> trace is below).
>> My questions are:
>> line:
>> to fail.
>> Thiago
>> SEVERE: exception:
>> SEVERE: null
>> at
>> at java.lang.reflect.Method.invoke(Method.java:597)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
>> : ASMModule}
>> ASMModule}
>> ASMModule]
>> SEVERE: null
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 26 more
Re: [ATL] Setting details of EAnnotations or maps in general [message #85429 is a reply to message #85413] |
Sat, 28 June 2008 14:37 |
Ed Merks Messages: 33133 Registered: July 2009 |
Thiago,
Comments below.
Thiago Tonelli Bartolomei wrote:
> Hi Brahim,
> thanks, it works!
That's exactly what it is, reflectively.
> So,
> details<-map
> details<-Set{map}
It would be a major complication for all reflective accessors to have to
deal with a case other than simply isMany being false/true. So yes it's
Ecore's "fault" but it's completely intentional. It's how we were able
to add support for maps without forcing everyone with reflective code to
change it...
> Thanks again!
> Thiago
>> Hi Thiago,
>> an EAnnotation :
>> from
>> c : UML!Comment
>> to
>> key <- 'name',
>> value <- c.body
>> details<-map
>> Regards,
>> Brahim
>>> Hi,
>>> from
>>> to
>>> Note that:
>>> java.util.List
>>> trace is below).
>>> My questions are:
>>> line:
>>> to fail.
>>> Thiago
>>> SEVERE: exception:
>>> SEVERE: null
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> : ASMModule}
>>> ASMModule}
>>> ASMModule]
>>> SEVERE: null
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 26 more
Ed Merks
Re: [ATL] Setting details of EAnnotations or maps in general [message #85443 is a reply to message #85429] |
Sat, 28 June 2008 03:44 |
Ed Merks wrote:
> Thiago,
> Comments below.
>> Hi Brahim,
>> thanks, it works!
>> So,
>> details<-map
>> details<-Set{map}
>> could do:
> change it...
Oh yes, I should have used "fault". I understand the issue and I know it was intentional.
Thiago
>> Thanks again!
>> Thiago
>>> Hi Thiago,
>>> an EAnnotation :
>>> from
>>> c : UML!Comment
>>> to
>>> key <- 'name',
>>> value <- c.body
>>> details<-map
>>> Regards,
>>> Brahim
>>>> Hi,
>>>> from
>>>> to
>>>> Note that:
>>>> java.util.List
>>>> trace is below).
>>>> My questions are:
>>>> line:
>>>> to fail.
>>>> Thiago
>>>> SEVERE: exception:
>>>> SEVERE: null
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> : ASMModule}
>>>> ASMModule}
>>>> ASMModule]
>>>> SEVERE: null
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 26 more
Current Time: Wed Apr 17 21:34:34 GMT 2024
Powered by FUDForum. Page generated in 0.02173 seconds
