Home » Eclipse Projects » EclipseLink » @Version and DescriptorException
@Version and DescriptorException [message #760320] Thu, 01 December 2011 20:57 Go to next message
Mauro Flores is currently offline Mauro FloresFriend
Member
I have an entity called Foo with an embedded class Boo. Both classes are declared in my persistence.xml. Boo is packaged in different jar than Foo. Foo is packaged in an EJB jar; Boo is packaged in an utility jar (app-inf/lib). Boo has a timestamp property.
Both jar are deployed and run successfully.
When I put @Version on timestamp property of Boo, I get following exception:
Exception [EclipseLink-93] (Eclipse Persistence Services - 2.1.3.v20110304-r9073): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: The table [FOO] is not present in this descriptor.
Descriptor: RelationalDescriptor(Foo --> [DatabaseTable(FOO)])
If I package Foo and Boo in the same ejb jar, this exception is not shown.
Thanks for any help.
Re: @Version and DescriptorException [message #761032 is a reply to message #760320] Mon, 05 December 2011 19:40 Go to previous messageGo to next message
James is currently offline JamesFriend
Odd. Can you include the full exception stack trace.
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Re: @Version and DescriptorException [message #810944 is a reply to message #761032] Thu, 01 March 2012 18:10 Go to previous messageGo to next message
Member
I'm back to this problem.
The problem happens only if I have two classes containing another one embedded and the embeded class has @Version property.
Foo is the Embedded class
Boo is one off the class that declares Foo
Doo is the other classe that declares Foo
The first time time I try to run the aplication I get the following exception:
Caused by:(5) org.eclipse.persistence.exceptions.IntegrityException
Descriptor Exceptions:
Descriptor: RelationalDescriptor(mypackage.Doo --> [DatabaseTable(DOO)])
Runtime Exceptions:
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:471)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:406)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.postConnectDatasource(DatabaseSessionImpl.java:666)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:615)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:228)
	... (6 lines)
	at weblogic.deployment.QueryProxyImpl.getResultList(QueryProxyImpl.java:124)
	at com.xyz.util.crud.CrudBDImpl.lista(CrudBDImpl.java:161)
	at com.xyz.util.crud.CrudBDImpl.lista(CrudBDImpl.java:179)
	at mypackage.aluno.AlunoRNImpl.lista(AlunoRNImpl.java:115)
The second:
	Caused by:(4) org.eclipse.persistence.exceptions.JPQLException
Exception Description: Error compiling the query [Doo.lista: select c from Doo c WHERE c.tituloCur LIKE :tituloCur AND c.vlrPreco = :vlrPreco], line 1, column 32: unknown state or association field [tituloCur] of class [mypackage.ed.Doo].
	at org.eclipse.persistence.exceptions.JPQLException.unknownAttribute(JPQLException.java:457)
	at org.eclipse.persistence.internal.jpa.parsing.DotNode.validate(DotNode.java:88)
	at org.eclipse.persistence.internal.jpa.parsing.LikeNode.validate(LikeNode.java:43)
	at org.eclipse.persistence.internal.jpa.parsing.Node.validate(Node.java:91)
	at org.eclipse.persistence.internal.jpa.parsing.LogicalOperatorNode.validate(LogicalOperatorNode.java:39)
	... (19 lines)
When I take the annotation @Version of Boo the problem disapear.
When just one Entity declares Boo the problem disapear too.
Re: @Version and DescriptorException [message #813716 is a reply to message #810944] Mon, 05 March 2012 16:34 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
This error does not occur if you package both classes in the same jar?
That is odd, please include your persistence.xml file.
James : Wiki : Book : Blog : Twitter
Re: @Version and DescriptorException [message #813858 is a reply to message #813716] Mon, 05 March 2012 19:49 Go to previous messageGo to next message
Member
It DOES happen even packaging all classes in the same jar.
I've just checked, the problem happens even if all classes have the same package (qualified name).
<persistence xmlns="http://java.sun.com/xml/ns/persistence"
	xsi:schemaLocation="http://java.sun.com/xml/ns/persistence
    http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd"
	version="1.0">
	<persistence-unit name="XYZ">
		<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
		<jta-data-source>XyzDS</jta-data-source>
		<mapping-file>META-INF/orm.xml</mapping-file>
		<class>Foo</class>
		<class>Boo</class>
		<class>Doo</class>
		<properties>
			<property name="eclipselink.logging.level" value="INFO" />
		</properties>
	</persistence-unit>
</persistence>
[Updated on: Mon, 05 March 2012 20:12]
Report message to a moderator
Re: @Version and DescriptorException [message #825161 is a reply to message #813858] Tue, 20 March 2012 14:53 Go to previous message
But you said in your first post,
So, that was false?
Try the latest release, this may have been something that was fixed. Otherwise log a bug, it seems like the version field is not getting initialized correctly.
Previous Topic:application freeze
Next Topic:"No [EntityType] was found" Error with Spring 3.0.5 and EclipseLink 2.3.2
Current Time: Sat Jun 06 11:49:41 GMT 2020
Powered by FUDForum. Page generated in 0.01961 seconds
