Unable to map object in the Inspector [message #760285] |
Thu, 01 December 2011 18:44 |
Carl Bader Messages: 15 Registered: November 2011 |
I am new to Jubula. I have gone through the help documentation but don't see anything that covers my issue.
I am trying understand the OM Inspector to capture object paths.
I have installed Jubula and extracted the rcp-support.zip into the plugins directory for the eclipse installation.
When I create a AUT (rcp) for the eclipse installation and then start the Inspector I can see the green outline around the area I want to capture the paths for but when I click on the object I don't get anything in the Inspector window. Am I doing something wrong or misunderstanding what the Inspector is for.
I checked the Show Client log and I have the following error listed. Could this be why I am not seeing paths? Is there a way to correct this issue.
I am working on testing a product that will be a plugin and RCP for eclipse so I will need to get the object paths to build the tests.
2011-12-01 10:27:45.396 [Worker-1] WARN o.e.jubula.client.core.ClientTest - No Basic Tester Class is defined for the Toolkit with ID 'com.bredexsw.guidancer.RcpToolkitPlugin'. No Simple Component Extensions will be added.
Jubula version: 1.1.0
Eclipse: 3.7.1
Workstation: Windows Vista 32 bit
[Updated on: Thu, 01 December 2011 18:50] Report message to a moderator
FUDForum. Page generated in 0.03001 seconds
