Home » Eclipse Projects » Virgo » userregionfactory failed to start
userregionfactory failed to start [message #760237] |
Thu, 01 December 2011 16:45 |
malik Messages: 13 Registered: November 2011 |
when virgo starts loading, after a couple of seconds it throws this exception:
org.osgi.framework.BundleException: Bundle org.eclipse.virgo.kernel.userregionfactory 3.0.1.RELEASE failed to start
but this happens only when i run virgo with -Xmx512m
when virgo runs with -Xmx1500m it runs just fine!
now I saw in the stack trace this line:
"Caused by: java.util.concurrent.TimeoutException"
so I think it's taking too long for virgo to load (because it has only -Xmx512m)
so if this is the problem is there a way to increase the loading time timeout?
and if not, why is this happening?
here the full stack trace:
2011-12-01 17:27:57.569 INFO [main] o.e.virgo.medic.eventlog.default - Dump 'serviceability/dump/2011-12-01-17-27-680' generated
2011-12-01 17:27:57.571 ERROR [main] System.err - org.osgi.framework.BundleException: Bundle org.eclipse.virgo.kernel.userregionfactory 3.0.1.RELEASE failed to start.
2011-12-01 17:27:57.572 ERROR [main] System.err - at org.eclipse.virgo.osgi.launcher.FrameworkBuilder.installAndStartBundles(FrameworkBuilder.java:189)
2011-12-01 17:27:57.572 ERROR [main] System.err - at org.eclipse.virgo.osgi.launcher.FrameworkBuilder.start(FrameworkBuilder.java:159)
2011-12-01 17:27:57.572 ERROR [main] System.err - at org.eclipse.virgo.osgi.launcher.Launcher.main(Launcher.java:54)
2011-12-01 17:27:57.573 ERROR [main] System.err - Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.virgo.kernel.userregionfactory.Activator.start() of bundle org.eclipse.virgo.kernel.userregionfactory.
2011-12-01 17:27:57.573 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
2011-12-01 17:27:57.573 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
2011-12-01 17:27:57.574 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
2011-12-01 17:27:57.575 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
2011-12-01 17:27:57.575 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:291)
2011-12-01 17:27:57.574 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, BundleEvent RESOLVED
2011-12-01 17:27:57.576 ERROR [main] System.err - at org.eclipse.virgo.osgi.launcher.FrameworkBuilder.installAndStartBundles(FrameworkBuilder.java:187)
2011-12-01 17:27:57.582 ERROR [main] System.err - ... 2 more
2011-12-01 17:27:57.583 ERROR [main] System.err - Caused by: org.osgi.framework.BundleException: Failed to start bundle org.eclipse.virgo.kernel.userregion 3.0.1.RELEASE
2011-12-01 17:27:57.583 ERROR [main] System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.initialiseUserRegionBundles(Activator.java:349)
2011-12-01 17:27:57.583 ERROR [main] System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.createUserRegion(Activator.java:178)
2011-12-01 17:27:57.584 ERROR [main] System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.start(Activator.java:133)
2011-12-01 17:27:57.584 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
2011-12-01 17:27:57.584 ERROR [main] System.err - at java.security.AccessController.doPrivileged(Native Method)
2011-12-01 17:27:57.585 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
2011-12-01 17:27:57.585 ERROR [main] System.err - ... 7 more
2011-12-01 17:27:57.585 ERROR [main] System.err - Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.virgo.kernel.userregion.internal.Activator.start() of bundle org.eclipse.virgo.kernel.userregion.
2011-12-01 17:27:57.582 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, Service 81, ServiceEvent REGISTERED
2011-12-01 17:27:57.586 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, Service 82, ServiceEvent REGISTERED
2011-12-01 17:27:57.587 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, BundleEvent STARTED
2011-12-01 17:27:57.587 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.userregion_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:27:57.587 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.userregionfactory_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:27:57.577 INFO [kernel-dm-3] o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [bundleentry://38.fwk12213211/META-INF/spring/osgi-context.xml]
2011-12-01 17:27:57.622 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
2011-12-01 17:27:57.628 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
2011-12-01 17:27:57.628 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
2011-12-01 17:27:57.629 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
2011-12-01 17:27:57.629 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:291)
2011-12-01 17:27:57.629 ERROR [main] System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.initialiseUserRegionBundles(Activator.java:345)
2011-12-01 17:27:57.629 ERROR [main] System.err - ... 12 more
2011-12-01 17:27:57.630 ERROR [main] System.err - Caused by: java.util.concurrent.TimeoutException: org.eclipse.virgo.repository.Repository
2011-12-01 17:27:57.636 ERROR [main] System.err - at org.eclipse.virgo.kernel.userregion.internal.Activator.getPotentiallyDelayedService(Activator.java:352)
2011-12-01 17:27:57.637 ERROR [main] System.err - at org.eclipse.virgo.kernel.userregion.internal.Activator.start(Activator.java:101)
2011-12-01 17:27:57.637 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
2011-12-01 17:27:57.637 ERROR [main] System.err - at java.security.AccessController.doPrivileged(Native Method)
2011-12-01 17:27:57.649 INFO [kernel-dm-1] o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [bundleentry://35.fwk12213211/META-INF/spring/io-context.xml]
2011-12-01 17:27:57.638 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
2011-12-01 17:27:57.683 INFO [kernel-dm-4] o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [bundleentry://39.fwk12213211/META-INF/spring/internal-osgi-context.xml]
2011-12-01 17:27:57.655 ERROR [main] System.err - ... 17 more
2011-12-01 17:27:57.688 INFO [kernel-dm-2] o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [bundleentry://36.fwk12213211/META-INF/spring/osgi-context.xml]
thanks in advance.
Re: userregionfactory failed to start [message #760259 is a reply to message #760237] |
Thu, 01 December 2011 17:22 |
This may be a sign of frequent GC. Can you please add the following JVM options:
-verbose:gc
-XX:+PrintGCTimeStamps
-XX:+PrintGCDetails
If this is the case you should be able to see a lot of GCs during a short time frame.
Re: userregionfactory failed to start [message #760686 is a reply to message #760628] |
Sun, 04 December 2011 08:51 |
hi agine,
I add the startup log and the the userregion.properties file after moifay.
startup log:
2011-12-01 17:27:06.036 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.medic.core_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.048 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.util.osgi_3.0.1.RELEASE, Service 51, ServiceEvent REGISTERED
2011-12-01 17:27:06.049 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.util.osgi_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.062 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.event_1.2.100.v20110110, Service 52, ServiceEvent REGISTERED
2011-12-01 17:27:06.070 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.event_1.2.100.v20110110, BundleEvent STARTED
2011-12-01 17:27:06.211 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.util.common_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.243 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.util.io_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.255 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.util.math_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.256 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.util.parser.manifest_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.256 INFO org.osgi.service.log.LogService - Bundle com.springsource.org.apache.commons.codec_1.3.0, BundleEvent STARTED
2011-12-01 17:27:06.256 INFO org.osgi.service.log.LogService - Bundle com.springsource.org.apache.commons.httpclient_3.1.0, BundleEvent STARTED
2011-12-01 17:27:06.369 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.repository_3.0.1.RELEASE, Service 53, ServiceEvent REGISTERED
2011-12-01 17:27:06.526 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.repository_3.0.1.RELEASE, Service 54, ServiceEvent REGISTERED
2011-12-01 17:27:06.553 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.repository_3.0.1.RELEASE, Service 55, ServiceEvent REGISTERED
2011-12-01 17:27:06.555 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.repository_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.555 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.556 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.agent.dm_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:07.942 INFO org.osgi.service.log.LogService - Bundle org.springframework.osgi.extender_1.2.1, Service 56, ServiceEvent REGISTERED
2011-12-01 17:27:07.945 INFO org.osgi.service.log.LogService - Bundle org.springframework.osgi.extender_1.2.1, Service 57, ServiceEvent REGISTERED
2011-12-01 17:27:08.823 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from OSGi resource
2011-12-01 17:27:12.147 INFO o.s.b.f.s.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@f63055: defining beans ; root of factory hierarchy
2011-12-01 17:27:12.695 INFO org.osgi.service.log.LogService - Bundle org.springframework.osgi.extender_1.2.1, Service 58, ServiceEvent REGISTERED
2011-12-01 17:27:13.243 INFO org.osgi.service.log.LogService - Bundle org.springframework.osgi.extender_1.2.1, BundleEvent STARTED
2011-12-01 17:27:13.337 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:13.713 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:13.948 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.ds_1.3.0.v20110124-0830, Service 59, ServiceEvent REGISTERED
2011-12-01 17:27:14.154 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:14.481 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.event_1.2.100.v20110110, Service 60, ServiceEvent REGISTERED
2011-12-01 17:27:15.501 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 61, ServiceEvent REGISTERED
2011-12-01 17:27:15.558 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 62, ServiceEvent REGISTERED
2011-12-01 17:27:15.756 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 63, ServiceEvent REGISTERED
2011-12-01 17:27:15.762 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:15.792 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 64, ServiceEvent REGISTERED
2011-12-01 17:27:15.793 INFO o.s.s.c.ThreadPoolTaskExecutor - Initializing ExecutorService
2011-12-01 17:27:15.867 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 65, ServiceEvent REGISTERED
2011-12-01 17:27:15.899 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 66, ServiceEvent REGISTERED
2011-12-01 17:27:16.098 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 67, ServiceEvent REGISTERED
2011-12-01 17:27:16.226 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 68, ServiceEvent REGISTERED
2011-12-01 17:27:16.257 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 69, ServiceEvent REGISTERED
2011-12-01 17:27:16.487 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:16.711 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 70, ServiceEvent REGISTERED
2011-12-01 17:27:16.770 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 71, ServiceEvent REGISTERED
2011-12-01 17:27:16.822 INFO o.e.virgo.medic.eventlog.default - Kernel starting.
2011-12-01 17:27:16.874 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 72, ServiceEvent REGISTERED
2011-12-01 17:27:16.882 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 72, ServiceEvent UNREGISTERING
2011-12-01 17:27:16.905 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 73, ServiceEvent REGISTERED
2011-12-01 17:27:17.014 INFO o.s.b.f.s.DefaultListableBeanFactory - Overriding bean definition for bean 'scopeFactory': replacing [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
2011-12-01 17:27:17.058 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:17.234 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.agent.dm_3.0.1.RELEASE, Service 74, ServiceEvent REGISTERED
2011-12-01 17:27:17.309 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.agent.dm_3.0.1.RELEASE, Service 75, ServiceEvent REGISTERED
2011-12-01 17:27:17.346 INFO o.s.b.f.s.DefaultListableBeanFactory - Overriding bean definition for bean 'kernelConfig': replacing [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
2011-12-01 17:27:24.405 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:17.657 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:17.592 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:17.564 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:17.361 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.agent.dm_3.0.1.RELEASE, Service 77, ServiceEvent REGISTERED
2011-12-01 17:27:24.455 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.ds_1.3.0.v20110124-0830, Service 76, ServiceEvent REGISTERED
2011-12-01 17:27:24.492 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.ds_1.3.0.v20110124-0830, Service 78, ServiceEvent REGISTERED
2011-12-01 17:27:24.494 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.ds_1.3.0.v20110124-0830, BundleEvent STARTED
2011-12-01 17:27:24.510 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.util_1.0.200.v20100503, Service 79, ServiceEvent REGISTERED
2011-12-01 17:27:24.563 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.util_1.0.200.v20100503, Service 80, ServiceEvent REGISTERED
2011-12-01 17:27:24.565 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.util_1.0.200.v20100503, BundleEvent STARTED
2011-12-01 17:27:24.566 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.artifact_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:24.566 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.services_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:24.566 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.model_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:24.567 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.shell_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:24.567 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.osgi_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:24.567 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, BundleEvent INSTALLED
2011-12-01 17:27:24.568 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.userregion_3.0.1.RELEASE, BundleEvent INSTALLED
2011-12-01 17:27:24.568 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.osgicommand_3.0.1.RELEASE, BundleEvent INSTALLED
2011-12-01 17:27:24.568 INFO org.osgi.service.log.LogService - Bundle org.eclipse.osgi.services_3.3.0.v20110110, BundleEvent INSTALLED
2011-12-01 17:27:24.569 INFO org.osgi.service.log.LogService - Bundle com.springsource.org.apache.mina.core_2.0.2, BundleEvent INSTALLED
2011-12-01 17:27:24.569 INFO org.osgi.service.log.LogService - Bundle org.apache.felix.gogo.command_0.8.0.v201105062003, BundleEvent INSTALLED
2011-12-01 17:27:24.570 INFO org.osgi.service.log.LogService - Bundle org.apache.felix.gogo.runtime_0.8.0.v201105062003, BundleEvent INSTALLED
2011-12-01 17:27:24.570 INFO org.osgi.service.log.LogService - Bundle org.apache.felix.gogo.shell_0.8.0.v201107131313, BundleEvent INSTALLED
2011-12-01 17:27:24.603 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.console.supportability_1.0.0.201108021516, BundleEvent INSTALLED
2011-12-01 17:27:24.604 INFO org.osgi.service.log.LogService - Bundle com.springsource.org.apache.sshd.core_0.5.0, BundleEvent INSTALLED
2011-12-01 17:27:24.604 INFO org.osgi.service.log.LogService - Bundle org.apache.felix.gogo.runtime_0.8.0.v201105062003, BundleEvent RESOLVED
2011-12-01 17:27:24.605 INFO org.osgi.service.log.LogService - Bundle org.apache.felix.gogo.shell_0.8.0.v201107131313, BundleEvent RESOLVED
2011-12-01 17:27:24.605 INFO org.osgi.service.log.LogService - Bundle org.apache.felix.gogo.command_0.8.0.v201105062003, BundleEvent RESOLVED
2011-12-01 17:27:24.606 INFO org.osgi.service.log.LogService - Bundle com.springsource.org.apache.mina.core_2.0.2, BundleEvent RESOLVED
2011-12-01 17:27:24.606 INFO org.osgi.service.log.LogService - Bundle com.springsource.org.apache.sshd.core_0.5.0, BundleEvent RESOLVED
2011-12-01 17:27:24.619 INFO org.osgi.service.log.LogService - Bundle org.eclipse.osgi.services_3.3.0.v20110110, BundleEvent RESOLVED
2011-12-01 17:27:24.620 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.console.supportability_1.0.0.201108021516, BundleEvent RESOLVED
2011-12-01 17:27:24.620 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.osgicommand_3.0.1.RELEASE, BundleEvent RESOLVED
2011-12-01 17:27:24.620 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.userregion_3.0.1.RELEASE, BundleEvent RESOLVED
2011-12-01 17:27:57.569 INFO o.e.virgo.medic.eventlog.default - Dump 'serviceability/dump/2011-12-01-17-27-680' generated
2011-12-01 17:27:57.571 ERROR System.err - org.osgi.framework.BundleException: Bundle org.eclipse.virgo.kernel.userregionfactory 3.0.1.RELEASE failed to start.
2011-12-01 17:27:57.572 ERROR System.err - at org.eclipse.virgo.osgi.launcher.FrameworkBuilder.installAndStartBundles(FrameworkBuilder.java:189)
2011-12-01 17:27:57.572 ERROR System.err - at org.eclipse.virgo.osgi.launcher.FrameworkBuilder.start(FrameworkBuilder.java:159)
2011-12-01 17:27:57.572 ERROR System.err - at org.eclipse.virgo.osgi.launcher.Launcher.main(Launcher.java:54)
2011-12-01 17:27:57.573 ERROR System.err - Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.virgo.kernel.userregionfactory.Activator.start() of bundle org.eclipse.virgo.kernel.userregionfactory.
2011-12-01 17:27:57.573 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
2011-12-01 17:27:57.573 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
2011-12-01 17:27:57.574 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
2011-12-01 17:27:57.575 ERROR System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
2011-12-01 17:27:57.575 ERROR System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:291)
2011-12-01 17:27:57.574 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, BundleEvent RESOLVED
2011-12-01 17:27:57.576 ERROR System.err - at org.eclipse.virgo.osgi.launcher.FrameworkBuilder.installAndStartBundles(FrameworkBuilder.java:187)
2011-12-01 17:27:57.582 ERROR System.err - ... 2 more
2011-12-01 17:27:57.583 ERROR System.err - Caused by: org.osgi.framework.BundleException: Failed to start bundle org.eclipse.virgo.kernel.userregion 3.0.1.RELEASE
2011-12-01 17:27:57.583 ERROR System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.initialiseUserRegionBundles(Activator.java:349)
2011-12-01 17:27:57.583 ERROR System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.createUserRegion(Activator.java:178)
2011-12-01 17:27:57.584 ERROR System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.start(Activator.java:133)
2011-12-01 17:27:57.584 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
2011-12-01 17:27:57.584 ERROR System.err - at java.security.AccessController.doPrivileged(Native Method)
2011-12-01 17:27:57.585 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
2011-12-01 17:27:57.585 ERROR System.err - ... 7 more
2011-12-01 17:27:57.585 ERROR System.err - Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.virgo.kernel.userregion.internal.Activator.start() of bundle org.eclipse.virgo.kernel.userregion.
2011-12-01 17:27:57.582 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, Service 81, ServiceEvent REGISTERED
2011-12-01 17:27:57.586 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, Service 82, ServiceEvent REGISTERED
2011-12-01 17:27:57.587 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, BundleEvent STARTED
2011-12-01 17:27:57.587 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.userregion_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:27:57.587 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.userregionfactory_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:27:57.577 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:57.622 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
2011-12-01 17:27:57.628 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
2011-12-01 17:27:57.628 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
2011-12-01 17:27:57.629 ERROR System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
2011-12-01 17:27:57.629 ERROR System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:291)
2011-12-01 17:27:57.629 ERROR System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.initialiseUserRegionBundles(Activator.java:345)
2011-12-01 17:27:57.629 ERROR System.err - ... 12 more
2011-12-01 17:27:57.630 ERROR System.err - Caused by: java.util.concurrent.TimeoutException: org.eclipse.virgo.repository.Repository
2011-12-01 17:27:57.636 ERROR System.err - at org.eclipse.virgo.kernel.userregion.internal.Activator.getPotentiallyDelayedService(Activator.java:352)
2011-12-01 17:27:57.637 ERROR System.err - at org.eclipse.virgo.kernel.userregion.internal.Activator.start(Activator.java:101)
2011-12-01 17:27:57.637 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
2011-12-01 17:27:57.637 ERROR System.err - at java.security.AccessController.doPrivileged(Native Method)
2011-12-01 17:27:57.649 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:57.638 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
2011-12-01 17:27:57.683 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:57.655 ERROR System.err - ... 17 more
2011-12-01 17:27:57.688 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:57.821 INFO o.s.b.f.s.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1347d33: defining beans ; root of factory hierarchy
2011-12-01 17:27:57.857 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:28:24.492 INFO o.s.b.f.s.DefaultListableBeanFactory - Overriding bean definition for bean 'kernelConfig': replacing [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
2011-12-01 17:28:24.492 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:28:24.703 INFO o.s.b.f.s.DefaultListableBeanFactory - Overriding bean definition for bean 'eventLogger': replacing [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
2011-12-01 17:29:03.601 INFO o.s.b.f.s.DefaultListableBeanFactory - Overriding bean definition for bean 'kernelConfig': replacing [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
2011-12-01 17:29:03.889 ERROR o.e.virgo.medic.eventlog.default - Application context creation failure for bundle 'org.eclipse.virgo.kernel.deployer' version '3.0.1.RELEASE'.
org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'osgiFramework': Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:209) ~
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288) ~
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190) ~
at org.springframework.osgi.extender.internal.dependencies.startup.MandatoryImporterDependencyFactory.getServiceDependencies(MandatoryImporterDependencyFactory.java:63) ~
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager.doFindDependencies(DependencyServiceManager.java:272) ~
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager.access$700(DependencyServiceManager.java:40) ~
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager$1.run(DependencyServiceManager.java:213) ~
at org.springframework.osgi.extender.internal.util.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:124) ~
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager.findServiceDependencies(DependencyServiceManager.java:209) ~
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.stageOne(DependencyWaiterApplicationContextExecutor.java:239) ~
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.refresh(DependencyWaiterApplicationContextExecutor.java:169) ~
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.refresh(AbstractDelegatedExecutionApplicationContext.java:175) ~
at org.springframework.osgi.extender.internal.activator.ContextLoaderListener$2.run(ContextLoaderListener.java:716) ~
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95) ~
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
2011-12-01 17:29:04.059 INFO o.s.b.f.s.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1ebe8ec: defining beans ; root of factory hierarchy
2011-12-01 17:29:32.636 ERROR o.e.virgo.medic.eventlog.default - Kernel failed to start.
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) ~
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) ~
2011-12-01 17:29:04.431 INFO o.s.b.f.s.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@24d517: defining beans ; root of factory hierarchy
2011-12-01 17:29:36.228 INFO o.s.b.f.s.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@c71c00: defining beans ; root of factory hierarchy
2011-12-01 17:29:36.637 INFO o.s.b.f.s.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@18ed284: defining beans ; root of factory hierarchy
2011-12-01 17:30:01.643 INFO o.e.virgo.medic.eventlog.default - Dump 'serviceability/dump/2011-12-01-17-29-637' generated
2011-12-01 17:30:01.665 INFO org.osgi.service.log.LogService - Bundle org.springframework.osgi.extender_1.2.1, Service 56, ServiceEvent UNREGISTERING
2011-12-01 17:30:27.486 INFO o.e.virgo.medic.eventlog.default - Immediate shutdown initiated.
2011-12-01 17:30:27.458 INFO org.osgi.service.log.LogService - Bundle org.springframework.osgi.extender_1.2.1, Service 58, ServiceEvent UNREGISTERING
2011-12-01 17:30:27.488 INFO o.s.b.f.s.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@f63055: defining beans ; root of factory hierarchy
2011-12-01 17:30:54.181 INFO o.e.virgo.medic.eventlog.default - Shutdown initiated.
2011-12-01 17:30:54.347 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, Service 82, ServiceEvent UNREGISTERING
2011-12-01 17:30:54.444 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, Service 81, ServiceEvent UNREGISTERING
2011-12-01 17:30:54.491 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, BundleEvent STOPPED
2011-12-01 17:30:54.521 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.osgi_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:30:54.535 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.shell_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:30:54.588 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.model_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:30:54.638 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.services_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:30:54.661 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.artifact_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:30:54.662 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.util_1.0.200.v20100503, Service 79, ServiceEvent UNREGISTERING
2011-12-01 17:30:54.724 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.util_1.0.200.v20100503, Service 80, ServiceEvent UNREGISTERING
this is the userregion.properties file:
baseBundles = \
file:lib/kernel/org.eclipse.equinox.cm-1.0.300.v20101204.jar@start,\
file:lib/kernel/org.eclipse.virgo.kernel.userregion-3.0.1.RELEASE.jar@start,\
file:lib/kernel/org.eclipse.virgo.kernel.osgicommand-3.0.1.RELEASE.jar@start,\
file:lib/kernel/org.eclipse.osgi.services-3.3.0.v20110110.jar@start,\
file:lib/kernel/com.springsource.org.apache.mina.core-2.0.2.jar@start,\
file:lib/kernel/org.apache.felix.gogo.command-0.8.0.v201107131313.jar@start,\
file:lib/kernel/org.apache.felix.gogo.runtime-0.8.0.v201107131313.jar@start,\
file:lib/kernel/org.apache.felix.gogo.shell-0.8.0.v201107131313.jar@start,\
file:lib/org.eclipse.equinox.console.supportability-1.0.0.201108021516.jar@start,\
file:lib/kernel/com.springsource.org.apache.sshd.core-0.5.0.jar@start
bundleImports = org.eclipse.osgi;bundle-version="0"
packageImports =\
org.eclipse.virgo.kernel.artifact.*;version="0",\
org.eclipse.virgo.kernel.core;version="0",\
org.eclipse.virgo.kernel.deployer.core;version="0",\
org.eclipse.virgo.kernel.deployer.core.event;version="0",\
org.eclipse.virgo.kernel.deployer.config;version="0",\
org.eclipse.virgo.kernel.install.*;version="0",\
org.eclipse.virgo.kernel.osgi.*;version="0",\
org.eclipse.virgo.kernel.model;version="0",\
org.eclipse.virgo.kernel.model.management;version="0",\
org.eclipse.virgo.kernel.module;version="0",\
org.eclipse.virgo.kernel.serviceability;version="0",\
org.eclipse.virgo.kernel.serviceability.*;version="0",\
org.eclipse.virgo.kernel.services.work;version="0",\
org.eclipse.virgo.kernel.shell;version="0",\
org.eclipse.virgo.kernel.shell.*;version="0",\
org.eclipse.virgo.kernel.shim.*;version="0",\
org.eclipse.virgo.medic.*;version="0",\
org.eclipse.virgo.repository;version="0",\
org.eclipse.virgo.repository.*;version="0",\
org.eclipse.virgo.util.*;version="0",\
org.apache.commons.logging;version="[1.0.0,2.0.0)",\
org.apache.commons.logging.impl;version="[1.0.0,2.0.0)",\
org.aspectj.*;version="[1.6.5.RELEASE,2.0.0)",\
org.osgi.service.event;version="0",\
org.osgi.service.log;version="0",\
org.eclipse.equinox.region;version="1",\
ch.qos.logback.*;version="[0.9.24,1.0.0)",\
org.slf4j;version="[1.6.1,2)",\
org.slf4j.helpers;version="[1.6.1,2)",\
org.slf4j.spi;version="[1.6.1,2)"
serviceImports =\
org.eclipse.equinox.region.Region,\
org.eclipse.equinox.region.RegionDigraph,\
org.osgi.framework.hooks.resolver.ResolverHookFactory,\
org.eclipse.virgo.kernel.deployer.core.ApplicationDeployer,\
org.eclipse.virgo.kernel.deployer.core.DeployUriNormaliser,\
org.eclipse.virgo.kernel.install.artifact.ScopeServiceRepository,\
org.eclipse.virgo.kernel.services.work.WorkArea,\
org.eclipse.virgo.repository.ArtifactBridge,\
org.eclipse.virgo.kernel.shell.state.StateService,\
org.eclipse.virgo.kernel.shell.CommandExecutor,\
org.eclipse.virgo.repository.RepositoryFactory,\
org.eclipse.virgo.repository.HashGenerator,\
org.eclipse.virgo.medic.eventlog.EventLoggerFactory,\
org.eclipse.virgo.repository.Repository,\
org.eclipse.virgo.kernel.core.Shutdown,\
org.osgi.service.event.EventAdmin,\
org.osgi.service.log.LogService,\
org.eclipse.virgo.medic.eventlog.EventLogger,\
org.eclipse.virgo.medic.dump.DumpGenerator,\
org.eclipse.virgo.kernel.shim.scope.ScopeFactory,\
org.eclipse.virgo.kernel.shim.serviceability.TracingService,\
org.eclipse.virgo.kernel.model.RuntimeArtifactRepository,\
org.eclipse.osgi.service.resolver.PlatformAdmin,\
org.osgi.service.packageadmin.PackageAdmin,\
org.eclipse.virgo.kernel.core.ConfigurationExporter
serviceExports =\
org.eclipse.virgo.kernel.install.artifact.InstallArtifactLifecycleListener,\
org.eclipse.virgo.kernel.install.artifact.ArtifactIdentityDeterminer,\
org.eclipse.virgo.kernel.install.pipeline.stage.transform.Transformer,\
org.eclipse.virgo.kernel.module.ModuleContextAccessor,\
org.eclipse.virgo.medic.dump.DumpContributor,\
org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory,\
org.eclipse.virgo.kernel.osgi.framework.OsgiFramework,\
org.eclipse.virgo.kernel.osgi.framework.ImportExpander,\
org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil,\
org.osgi.service.event.EventHandler,\
org.osgi.framework.BundleContext,\
org.eclipse.virgo.kernel.deployer.config.ConfigurationDeployer
initialArtifacts=repository:plan/org.eclipse.virgo.kernel.userregion.springdm, repository:plan/org.eclipse.virgo.web.tomcat,repository:plan/server.plan
thanks agine.
Current Time: Thu Apr 25 14:18:52 GMT 2024
Powered by FUDForum. Page generated in 0.04291 seconds
