Home » Modeling » TMF (Xtext) » Terminal confusion
Terminal confusion [message #760144] Thu, 01 December 2011 13:34 Go to next message
Andreas Graf is currently offline Andreas GrafFriend
Dear Xtext-Gurus,
in which order are terminals matched during the parsing?
I am running into the following problem. My grammar both has possibilities to specify multiplicities
Multiplicity: "[" lower=INT ('..' (upper=INT|unbounded?='*'))? "]";
as well as NUMBER (used at some other place)
    terminal NUMBER returns ecore::EBigDecimal:
	('-')?('0'..'9')+ ('.' ('0'..'9')+);
Before introducing NUMBER, multiplicities worked fine with a syntax like this :
 [2..3]
However, this now results in:
Multiple markers at this line
- required (...)+ loop did not match anything at character '.'
- extraneous input '.' expecting RULE_INT
and I have to add extra whitespace.
 [2..3]
I have now idea why it gets confused, because NUMBER should not match anything in that statement.
Any ideas?
Andreas
Re: Terminal confusion [message #760147 is a reply to message #760144] Thu, 01 December 2011 13:39 Go to previous messageGo to next message
Alexander Nittka is currently offline Alexander NittkaFriend
terminals are *greedy*. As soon as "2." is read, the lexer goes on trying to match NUMBER and fails. This is why you would define number as a datatype rule rather than a terminal rule.
Alex
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext@itemis.de
Re: Terminal confusion [message #760148 is a reply to message #760147] Thu, 01 December 2011 13:41 Go to previous messageGo to next message
Thanks, that helps. So greedy in that context means not only that the regexp is greedy, but that ANTLR/Xtext does not try any other combinations.
Re: Terminal confusion [message #760163 is a reply to message #760148] Thu, 01 December 2011 13:59 Go to previous messageGo to next message
Indeed. Lexing is done before parsing, independent of the rest of the grammar (i.e. just terminal rules and keywords). As long as the token can be made "longer", the lexer goes on. And as there is a rule that fits the prefix "2.", it is chosen even if it is a dead end.
This is why you try to reduce the number of terminal rules to the absolute minimum and do as much using datatype rules as possible.
Alex
Re: Terminal confusion [message #760167 is a reply to message #760144] Thu, 01 December 2011 14:08 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Andreas,
please use a data type rule to model NUMBERs.
Sebastian
Am 01.12.11 14:34, schrieb Andreas Graf:
> Dear Xtext-Gurus,
> this :
> [2..3]
> [2..3]
> Any ideas?
> Andreas
Re: Terminal confusion [message #760213 is a reply to message #760167] Thu, 01 December 2011 15:51 Go to previous messageGo to next message
I used datatype rule for NUMBER, but that still gets into conflicts with the terminal INT. I tried to replace INT in my grammar with DINT, but that then conflicts with the parts where I reference an XExpression.
XExpression internally uses INT, which is not datatype rule (shouldn't it be, then?)
Redefining XIntLiteral to use my DINT results in an ambiguous grammar Sad
Did anybody already manage to integrate NUMBERs with INTs in their grammars (and I need the ".." syntax for multiplicities
Andreas
Re: Terminal confusion [message #760216 is a reply to message #760213] Thu, 01 December 2011 15:56 Go to previous messageGo to next message
what does your NUMBER rule lool like?
make sure it does not start with
"terminal NUMBER..." because then it is a terminal rule. It should look something like
NUMBER returns ecore::EBigDecimal: ('-')?('0'..'9')+ ('.' ('0'..'9')+)?;
Re: Terminal confusion [message #760309 is a reply to message #760216] Thu, 01 December 2011 20:05 Go to previous messageGo to next message
Or probably
Number returns EBigDecimal hidden(): '-'? INT ('.' INT)?;
Just to be picky :-)
Andreas, a terminal can usually not conflict with a data type rule. You
have to make sure to not use Number and INT in an alternative.
Sebastian
Am 01.12.11 16:56, schrieb Alexander Nittka:
> something like
Re: Terminal confusion [message #760333 is a reply to message #760216] Thu, 01 December 2011 22:35 Go to previous messageGo to next message
Hi Alexander,
is "('0'..'9')" supposed to work in data type rules? For me it seemed to only work for terminals and I had to use "'0'|'1'|'2' etc." in data type rules.
Andreas
Re: Terminal confusion [message #760359 is a reply to message #760333] Fri, 02 December 2011 06:48 Go to previous message
Sorry,
of course you reference other terminal or datatype rules in the Number-rule:
Number: ('-')? INT ('.'INT)?;
Alex
Previous Topic:Formatting-Indent, documentation out of date
Next Topic:Floats and qualified ids...
Current Time: Mon Apr 19 09:47:13 GMT 2021
Powered by FUDForum. Page generated in 0.02664 seconds
