Re: Interactive chart [message #759979 is a reply to message #759894] |
Wed, 30 November 2011 19:05 |
Sure just use the hyperlink builder in the third tab of the chart wizard
(interactivity) to point to drill through. In fact you can have a data
point have multiple drill through paths. I am posting two interactivity
posts I did a while ago, that show invoking client side script.
http://birtworld.blogspot.com/2009/12/calling-client-side-javascript-from.html
http://birtworld.blogspot.com/2010/05/more-on-chart-interactivity.html
While you do not need these they should show you how to open the
interactivity editor.
Btw BIRT also supports server side scripting on chart.
http://birtworld.blogspot.com/2010/08/birt-charting-scripting-overview.html
Jason
On 11/30/2011 8:50 AM, srikanth wrote:
> Hi all,
> Is there a way we can generate a interactive chart in BIRT.For example,
> A chart is generated and is there a way the user can click on any
> segment of the generated report and we can generated another report..
> any suggestions will be really helpfull..
> Regards,
> Srikanth
Re: Interactive chart [message #761573 is a reply to message #761410] |
Tue, 06 December 2011 17:13 |
On ad hoc reporting do you mean changing the report based on parameters?
If so this can be done by using scripting or property binding to
modify the query that is executed or by using the design engine api in
the beforeFactory event to alter the report. There are many examples of
this on birtworld and birt-exchange dev share.
On dashboards, you could use the BIRT tag libraries to do this?
http://www.eclipse.org/birt/phoenix/deploy/viewerUsageMain.php#tags
If you only want to render one portion of a report say a chart put a
bookmark property on it in the design and then use the reportletid
attribute. You may also want to look over this post:
http://birtworld.blogspot.com/2007/09/22-birt-tag-library-building-custom.html
Jason
On 12/6/2011 7:47 AM, srikanth wrote:
> Thank you Jason.... It was really helpfull..
> I am trying out the following features can you please help me out with the,
> 1)AD HOC REPORTING
> 2)DASHBOARDS
> Regards,
> Srikanth
Re: Interactive chart [message #1270700 is a reply to message #761573] |
Thu, 13 March 2014 10:53 |
hamza laaroussi Messages: 2 Registered: March 2014 |
That was really helpful to me too, Thank you Jason
But remained one concern related to my current project, it is the fact that i should integrate reporting module with a web application based on JEE(Hibernate, Spring , JSF 1.2) architecture
is that gonna possible using Birt ?
[Updated on: Thu, 13 March 2014 11:59] Report message to a moderator
FUDForum. Page generated in 0.03511 seconds
