Searching for Binaries [message #759887] |
Wed, 30 November 2011 13:39 |
Thomas . Messages: 32 Registered: July 2009 |
Member |
Could someone please tell me what "Searching for Binaries (<project>)" is?
This task is always running in my Eclipse progress view without ever ending.
How can I turn this thing off? What is it supposed to do?
Thank you very much in advance!
Thomas
Re: Searching for Binaries [message #760851 is a reply to message #760841] |
Mon, 05 December 2011 12:50 |
Member |
Axel Mueller wrote on Mon, 05 December 2011 13:29Klaus wrote on Fri, 02 December 2011 19:32Thomas wrote on Fri, 02 December 2011 07:29
The selection of the binary parser has no effect to my problem.
Hello Thomas,
even if you deselect all binary parsers, a binary parser is running?
On my PC (Windows+Indigo+CDT8) i can switch on or off the binary parser and it seems to work as expected.
If in your case the binary parser is running, even if you have deselect all parsers, than it looks like a Eclipse bug to me. Maybe you should drop an entry into eclipses bugzilla.
Klaus
I guess there is some misunderstanding on your side. I did not suggest to disable the binary parsers completely but to limit the search scope.
@Klaus: It seems I got you wrong in first instance. I selected different binary parsers, but did not deselect all of them. After reading the help pages you have posted, I felt interested in retaining the functionality...
@Axel: That's what I did: I added a filter to exclude some problematic files. Now the parser starts, but comes to an end. This solved my original problem.
Thank you both for your kind assistance!
Thomas
Re: Searching for Binaries [message #1849588 is a reply to message #1270115] |
Wed, 26 January 2022 11:29 |
Zdeněk Ziegler Messages: 22 Registered: November 2019 |
Hello everyone,
I have encountered the same error as Thomas in the past, but I causes a lot of troubles. Whole eclipse is glitching and after a while it stops responding at all, because Binary parser creates workers searching for a specific file 'XYZ.so' , which are running without end while consuming a lot of Eclipses resources.
- I double checked the project settings -> Paths and Symbols -> Output location and it contains only the projects bin folder, nothing else.
- I also tried to apply filter for specific file 'XYZ.so' , to exclude this problematic file.
But it still run process: "Searching for Binaries (<project>): XYZ.so"
This problem stops only if I turn of all Binary Parsers for given project, but I honestly (I am not C++ developer) do not know how much these parser are important for normal C++ developers work. So i would like to manage this problem in another way.
Can somebody help me, please?
Another fact:
- 'XYZ.so' file really exists in projects bin folder (its subfolder), but given build finished with failure, so given file can be somehow corrupted, but I think it should not broke IDE like it does.
- If i go in C/C++ Projects views to given bin folder and location of 'XYZ.so' file, I am unable to unfold files parent folder and whole Eclipse stops responding until I kill it via Process manager.
Thank you in advance for replies.
Zdenek
FUDForum. Page generated in 0.04089 seconds
