Handling error in gmf [message #759549] |
Tue, 29 November 2011 06:59 |
vinny503 Missing name Messages: 156 Registered: August 2011 |
I get the following error when I double click on my gmf diagram file in navigator window...Can anyone help me regarding this..here usecase.omsbuilder is my gmf diagram file.
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Value '0' is not legal. (platform:/resource/test/usecase.omsbuilder, 5, 2361)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLLoadImpl.java:83)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:191)
at org.eclipse.gmf.runtime.emf.core.resources.GMFLoad.load(GMFLoad.java:51)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1282)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal.util.DiagramIOUtil$FileLoader.load(DiagramIOUtil.java:83)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal.util.DiagramIOUtil.load(DiagramIOUtil.java:160)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal.util.DiagramIOUtil.load(DiagramIOUtil.java:145)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.document.FileDiagramDocumentProvider.setDocumentContentFromStorage(FileDiagramDocumentProvider.java:156)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.document.StorageDocumentProvider.setDocumentContent(StorageDocumentProvider.java:152)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.document.FileDiagramDocumentProvider.setDocumentContent(FileDiagramDocumentProvider.java:275)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.document.StorageDocumentProvider.createDocument(StorageDocumentProvider.java:76)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.document.FileDocumentProvider.createElementInfo(FileDocumentProvider.java:476)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.document.AbstractDocumentProvider.connect(AbstractDocumentProvider.java:387)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.doSetInput(DiagramDocumentEditor.java:460)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.setInput(DiagramDocumentEditor.java:423)
at org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEditor.java:346)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.init(DiagramEditor.java:653)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.init(DiagramDocumentEditor.java:126)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1254)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1207)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1606)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:497)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:483)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2860)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2682)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:99)
at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:99)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
at org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:185)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:845)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:843)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1131)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:462)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1235)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at omsbuilder.diagram.application.OmsbuilderApplication.start(OmsbuilderApplication.java:22)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Vinay
[Updated on: Tue, 29 November 2011 07:36] Report message to a moderator
Re: Handling error in gmf [message #759581 is a reply to message #759568] |
Tue, 29 November 2011 09:12 |
Ed Merks Messages: 33133 Registered: July 2009 |
Eclipse has exception breakpoints; you'll see a button for that in the
breakpoints view, so that's one way. Of course you could set a
breakpoint in the constructor for the exception you see being thrown.
And of course you could set a breakpoint in XMLLoadImpl.handleErrors
which you see on the stack. Investing some time now to learn the tools
well will save you a lot of time in the future.
On 29/11/2011 9:42 AM, vinny503 wrote:
> May I know In which class should I set the breakpoint ?
> Regards,
> Vinay
Ed Merks
FUDForum. Page generated in 0.03204 seconds
