Home » Modeling » TMF (Xtext) » [eclipse] Problem upgrading to xtext 2.1.1
[eclipse] Problem upgrading to xtext 2.1.1 [message #759115] Sat, 26 November 2011 14:09 Go to next message
Goran   is currently offline Goran Friend
Member
I have a strange problem when trying to upgrade to xtext 2.1.1 using the update site
http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/
With a fresh "Xtext 2.1.0 Distribution (Indigo)" install in Ubuntu 64bit I get the following error when doing an update using the update site above:
Cannot complete the install because of a conflicting dependency.
  Software being installed: Xtext SDK 2.1.1.v201111141332 (org.eclipse.xtext.sdk.feature.group 2.1.1.v201111141332)
  Software currently installed: Shared profile 1.0.0.1320837589035 (SharedProfile_SDKProfile 1.0.0.1320837589035)
  Only one of the following can be installed at once:
    Xtext UI Shared 1.0.2.v201102150722 (org.eclipse.xtext.ui.shared 1.0.2.v201102150722)
    Xtext UI Shared 2.1.1.v201111141332 (org.eclipse.xtext.ui.shared 2.1.1.v201111141332)
    Xtext UI Shared 2.1.0.v201111010612 (org.eclipse.xtext.ui.shared 2.1.0.v201111010612)
    Xtext UI Shared 2.0.0.v201106070531 (org.eclipse.xtext.ui.shared 2.0.0.v201106070531)
  Cannot satisfy dependency:
    From: Shared profile 1.0.0.1320837589035 (SharedProfile_SDKProfile 1.0.0.1320837589035)
    To: org.eclipse.xtext.ui.shared [2.1.0.v201111010612]
    From: Xtext SDK 2.1.1.v201111141332 (org.eclipse.xtext.sdk.feature.group 2.1.1.v201111141332)
    To: org.eclipse.xtext.ui.feature.group [2.1.1.v201111141332]
    From: Xtext UI 2.1.1.v201111141332 (org.eclipse.xtext.ui.feature.group 2.1.1.v201111141332)
    To: org.eclipse.xtext.ui.shared [2.1.1.v201111141332]
What could the problem be?
Thanks in advanced
Re: [eclipse] Problem upgrading to xtext 2.1.1 [message #759218 is a reply to message #759115] Sun, 27 November 2011 18:52 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Goran,
how did you try to update the installation? It usually works if you
select 'Install New Software' and pick the Xtext SDK.
Sebastian
Am 26.11.11 15:09, schrieb Goran:
> update site
> Only one of the following can be installed at once: Xtext UI Shared
> Thanks in advanced
Re: [eclipse] Problem upgrading to xtext 2.1.1 [message #759234 is a reply to message #759218] Sun, 27 November 2011 22:51 Go to previous messageGo to next message
Member
I also tried "Install new Software" -> Choose "TMF Xtext-2.1.1". I then get the following error:
Your original request has been modified.
  Xtext SDK will be ignored because it is already installed, and updates are not permitted.
  Software being installed: Xtext UI 2.1.1.v201111141332 (org.eclipse.xtext.ui.feature.group 2.1.1.v201111141332)
  Software currently installed: Xtext SDK 2.1.0.v201111010612 (org.eclipse.xtext.sdk.feature.group 2.1.0.v201111010612)
    Common Types Shared State 2.1.1.v201111141332 (org.eclipse.xtext.common.types.shared 2.1.1.v201111141332)
    Common Types Shared State 2.1.0.v201111010612 (org.eclipse.xtext.common.types.shared 2.1.0.v201111010612)
    From: Xtext SDK 2.1.0.v201111010612 (org.eclipse.xtext.sdk.feature.group 2.1.0.v201111010612)
    To: org.eclipse.xtext.ui.feature.group [2.1.0.v201111010612]
    From: Xtext UI 2.1.0.v201111010612 (org.eclipse.xtext.ui.feature.group 2.1.0.v201111010612)
    To: org.eclipse.xtext.common.types.shared [2.1.0.v201111010612]
    To: org.eclipse.xtext.common.types.shared [2.1.1.v201111141332]
Remember that I get this using a fresh "Xtext 2.1.0 Distribution (Indigo)" 64 bit installation on Linux.
Re: [eclipse] Problem upgrading to xtext 2.1.1 [message #759258 is a reply to message #759234] Mon, 28 November 2011 06:39 Go to previous messageGo to next message
Goran,
please file a ticket.
Sebastian
Am 27.11.11 23:51, schrieb Goran:
> are not permitted.
> Only one of the following can be installed at once: Common Types Shared
Re: [eclipse] Problem upgrading to xtext 2.1.1 [message #760005 is a reply to message #759258] Wed, 30 November 2011 21:35 Go to previous messageGo to next message
Member
It seems that this is an issue of Eclipse.
I was able to circumvent this by running the update process as administrator.
Then restart eclipse as a normal user.
See http://tinyurl.com/6kuh5ya
~ Goran
[Updated on: Wed, 30 November 2011 21:36]
Report message to a moderator
Re: [eclipse] Problem upgrading to xtext 2.1.1 [message #762010 is a reply to message #760005] Wed, 07 December 2011 12:22 Go to previous message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
On 11/30/2011 10:35 PM, Goran wrote:
> It seems that this is an issue of Eclipse Indigo.
> administrator.
> ~ Goran
I'm experiencing the same problem with an xtext 2.0 distribution
downloaded from itemis...
but I can't see your bug, can you please provide the complete URL?
have you managed to solve the problem?
thanks in advance
Lorenzo
Previous Topic:Where has the OnTheFlyCompiler gone?
Next Topic:Buils xtext projects issues
Current Time: Tue Apr 13 05:54:54 GMT 2021
Powered by FUDForum. Page generated in 0.02007 seconds
