Is there anyway to override the dropAssistant from org.eclipse.ui.navigator.resourceContent? [message #759494 is a reply to message #758870] |
Mon, 28 November 2011 19:47 |
John Bodkin Messages: 39 Registered: November 2011 |
Member |
It all boils down to including org.eclipse.ui.navigator.resourceContent (contentExtension) in the org.eclipse.ui.navigator.viewer extension as a viewerContentBinding.
If you don't include org.eclipse.ui.navigator.resourceContent then my dropAssistant is used. But I lose Copy, Paste, Delete, Move... and Rename... from the context menu which is defined in org.eclipse.ui.navigator.resourceContent as actionProviders. You also lose the two common wizards and commonSorter both of which I'm less interested in.
Copying everything from org.eclipse.ui.navigator.resourceContent except the dropAssistant into your own navigatorContent definition doesn't work either. Copy, Paste, Delete, etc. don't appear on the context menu.
Is there any way to override the dropAssistant from org.eclipse.ui.navigator.resourceContent?
[Updated on: Mon, 28 November 2011 21:35] Report message to a moderator
FUDForum. Page generated in 0.03551 seconds
