Home » Eclipse Projects » Equinox » Method not accessible
Method not accessible [message #758605] Wed, 23 November 2011 20:37 Go to next message
Jakob Braeuchi is currently offline Jakob BraeuchiFriend
Member
hi,
i do have a problem with the visibility of inherited methods.
bundle1
- package internal.test is NOT exported. it contains an abstract class with methodA()
- package test is exported, this package contains the concrete class inherited from the class in internal.test. this class has a method methodB()
bundle2 requires bundle1
- i create an instance of the concrete class and call methodA() and methodB()
- methodB() is ok but the compiler complains about methodA() being not accessible.
exporting internal.test is not an option, setting the errors/warnings for forbidden access to warning is also not an option. i could implement methodA() in the concrete class as well but i think this is not the way to go.
things get even worse when i add an interface to the public package and have the abstract class implement this interface. with this scenarion methodA() of the concrete class still produces an error, but when i cast this instance to the interface it works:
        TheClass cls = new TheClass();
        // ok
        cls.methodB();
        // method not visible because the package internal.test of bundle test.bundle1
        // is not exported
        cls.methodA();
        // ok
        ((TheInterface)cls).methodA();
i have attached a zip with the two bundles to demonstrate this problem.
thanks jakob
  • Attachment: OSGiTest.zip
    (Size: 8.52KB, Downloaded 174 times)
Re: Method not accessible [message #758608 is a reply to message #758605] Wed, 23 November 2011 20:45 Go to previous messageGo to next message
Member
forgot to mention that i can successfully call methodA() and methodB() from a TestCase although the compiler marks an error
Re: Method not accessible [message #759279 is a reply to message #758605] Mon, 28 November 2011 09:04 Go to previous messageGo to next message
Ivan Larionov is currently offline Ivan LarionovFriend
Member
Hi Jakob,
I cannot provide a solution. I can just suggest a workaround.
You may try to export "internal.test" this way:
Export-Package: internal.test; x-internal:=true,
test
Then, while importing dependencies via Require-Bundle, you will be able
to use that method, though getting a warning in place of its invocation
instead of the error.
I am pretty sure someone can suggest a better way. I am looking forward
to it as well.
Ivan
On 23.11.2011 22:37, Jakob Braeuchi wrote:
> hi,
> bundle1
> // ok
> cls.methodB();
> // is not exported
> cls.methodA();
> // ok
> thanks jakob
Re: Method not accessible [message #760762 is a reply to message #759279] Mon, 05 December 2011 06:45 Go to previous messageGo to next message
Member
hi ivan,
thanks for your hint. as you wrote, i got a warning in my code.
actually i do not like to tweak my manifest or my code to solve
a problem that's probably an eclipse error.
jakob
Re: Method not accessible [message #760766 is a reply to message #760762] Mon, 05 December 2011 08:00 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Could this be a variation of
http://mcaffer.com/2011/01/managing-development-time-dependencies/
Tom
Am 05.12.11 07:45, schrieb Jakob Braeuchi:
> hi ivan,
> actually i do not like to tweak my manifest or my code to solve a
> jakob
Re: Method not accessible [message #764462 is a reply to message #760766] Mon, 12 December 2011 08:23 Go to previous messageGo to next message
Member
hi tom,
thanks for the link.
but i dont't think it's the same problem. this guy describes plugin dependencies; but i do have issues with package visibility and PDE's Automated Management of Dependencies is no help.
jakob
Re: Method not accessible [message #765107 is a reply to message #760766] Tue, 13 December 2011 12:37 Go to previous message
Member
I am afraid it is not.
> Tom
>> hi ivan,
>> jakob
Previous Topic:provisioning question
Next Topic:Jetty hosted in Equinox: can Jetty code access Equionox hosted bundles?
Current Time: Sun Nov 28 02:27:03 GMT 2021
Powered by FUDForum. Page generated in 0.01822 seconds
