Home » Modeling » TMF (Xtext) » Solution to content assist...Internal<project>Parser.java static initiailizer size limit
Solution to content assist...Internal<project>Parser.java static initiailizer size limit [message #758365] Tue, 22 November 2011 21:42 Go to next message
John J. Franey is currently offline John J. FraneyFriend
Member
After running the xtext workflow on my grammar, I got this error:
The code for the static initializer is exceeding the 65535 bytes limit InternalProjectParser.java /org.jjflyboy.tjpeditor.ui/src-gen/org/jjflyboy/tjpeditor/ui/contentassist/antlr/internal line 23 Java Problem
antlr has a resolution which I found on their email archive with a google, so I applied this with:
parser.antlr.XtextAntlrGeneratorFragment {
   antlrParam = "-Xmaxinlinedfastates" antlrParam = "100000"
   antlrParam = "-Xmaxswitchcaselabels" antlrParam = "30000"
   antlrParam = "-Xminswitchalts" antlrParam="1"
That had no effect.
It took me a while to notice that the fragment above is not the one that generates the content assist parser. So, then I applied the antlr params to:
// generates a more lightweight Antlr parser and lexer tailored for content assist
fragment = parser.antlr.XtextAntlrUiGeneratorFragment {
Now, I do not have the problem. Thanks to the xtext team for allowing this to be straight forward and user-understandable.
Re: Solution to content assist...Internal&lt;project&gt;Parser.java static initiailizer size [message #758483 is a reply to message #758365] Wed, 23 November 2011 12:34 Go to previous messageGo to next message
Jan Koehnlein is currently offline Jan KoehnleinFriend
Please try to set
options = {
classSplitting=true
in all Antlr fragments.
Am 22.11.11 22:42, schrieb John J. Franey:
> Quote:
> That had no effect.
> to:
> content assist
Get professional support from the Xtext committers at www.typefox.io
Re: Solution to content assist...Internal&lt;project&gt;Parser.java static initiailizer size [message #758507 is a reply to message #758483] Wed, 23 November 2011 13:56 Go to previous message
Member
Thank you.
Previous Topic:Xtext 2.1: using Xbase expressions
Next Topic:get current name file
Current Time: Mon Apr 12 07:48:07 GMT 2021
Powered by FUDForum. Page generated in 0.02007 seconds
