Warnings about skipped event handling in Stardust log file [message #758066] |
Mon, 21 November 2011 20:31 |
I see the following warnings in the IPP log repeated over and over again.
<Nov 17, 2011 5:54:18 PM EST> <Warning> <ag.carnot.workflow.runtime.beans.AuditTrailLogger> <000000> <Skipping event handling for aborted Process instance = 3081025 (Process Definition: Engine Report Extract) (User: system_carnot_engine (Realm: system_carnot_engine) (system_carnot_engine, system_carnot_engine))>
<Nov 17, 2011 5:54:18 PM EST> <Warning> <ag.carnot.workflow.runtime.beans.AuditTrailLogger> <000000> <Skipping event handling for aborted Process instance = 3081026 (Process Definition: Engine Report Extract) (User: system_carnot_engine (Realm: system_carnot_engine) (system_carnot_engine, system_carnot_engine))>
<Nov 17, 2011 5:54:18 PM EST> <Warning> <ag.carnot.workflow.runtime.beans.AuditTrailLogger> <000000> <Skipping event handling for aborted Process instance = 3081027 (Process Definition: Engine Report Extract) (User: system_carnot_engine (Realm: system_carnot_engine) (system_carnot_engine, system_carnot_engine))>
<Nov 17, 2011 5:54:18 PM EST> <Warning> <ag.carnot.workflow.runtime.beans.AuditTrailLogger> <000000> <Skipping event handling for aborted Process instance = 3081008 (Process Definition: Engine Report Extract) (User: system_carnot_engine (Realm: system_carnot_engine) (system_carnot_engine, system_carnot_engine))>
How do you analyze and fix this?
Re: Warnings about skipped event handling in Stardust log file [message #758081 is a reply to message #758066] |
Mon, 21 November 2011 20:44 |
This problem was seen in older versions of Stardust (Infinity Process Platform) when process instances were aborted and entries in the EVENT_BINDING table were not cleaned up properly. Since these represent scheduled events that are obsolete (due to the process having been aborted), these entries can be removed. The following SQL statements help identifying and deleting these entries (process instance state "1" -> aborted).
select * from PROCESS_INSTANCE p
join ACTIVITY_INSTANCE a on p.oid = a.processinstance
join EVENT_BINDING e on a.oid = e.OBJECTOID
where e.type=1 and p.state=1;
delete from EVENT_BINDING
where OID in (select e.oid from PROCESS_INSTANCE p
where e.type=1 and p.state=1);
FUDForum. Page generated in 0.03531 seconds
