Home » Archived » BIRT » Advanced Properties 'Inherited' in Layout-Hierarchies ?
Re: Advanced Properties 'Inherited' in Layout-Hierarchies ? [message #757825 is a reply to message #757816] |
Wed, 16 November 2011 17:14 |
Robert,
Can you create a report with the issue using sample data and post it?
Jason
On 11/15/2011 4:09 PM, Robert Aust wrote:
> Hi there,
> Can someone explain to me what this 'inherited' behind properties of
> Cells, Rows, etc means ?
> When I have a layout with GRID=>ROW=>CELL=>DATA it sometimes shows this
> 'inherited' behind the 'overflow'-property.
> But I still have to set it manually thru the whole hierarchie to make it
> work, that is, to have the layout expand in this case of
> 'overflow:visible'.
> Am I missing something here ?
> Btw - I am still using Birt 2.5.2.
> Robert
Re: Advanced Properties 'Inherited' in Layout-Hierarchies ? [message #757827 is a reply to message #757825] |
Wed, 16 November 2011 21:13 |
Robert Aust Messages: 17 Registered: July 2009 |
Hi Jason,
I tried - but did not get the problem in the sample report.
In my other reports I sometimes had to manually set
- overflow : visible
- pushdown : true
thru the whole hierarchy GRID->ROW->CELL->DATA in order to have the data
expand and show longer texts/use more vertical space. - If not it would
just be cut off.
In this sample report I did not touch these properties at all and still
it works, i.e. shows all the full product descriptions.
Here the designer shows this 'inherited' behind the properties in
the 'Advanced' tab. Is there some sort of default ?
How and in what direction does this inheritance work?
Robert
Here is the sample report
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.5.2.v20100208
Build <2.5.2.v20100210-0630></property>
<property name="units">cm</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
name="DS_SAMPLE" id="7">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver</property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet"
name="Q_SAMPLE" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTNAME</property>
<text-property name="displayName">PRODUCTNAME</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTDESCRIPTION</property>
<text-property name="displayName">PRODUCTDESCRIPTION</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTNAME</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">PRODUCTDESCRIPTION</property>
</structure>
</list-property>
</structure>
<property name="dataSource">DS_SAMPLE</property>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">PRODUCTNAME</property>
</structure>
<structure>
<property name="nativeName">PRODUCTDESCRIPTION</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select PRODUCTCODE, PRODUCTNAME,
PRODUCTDESCRIPTION
from products]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0"
encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:formattingHints>
<design:displaySize>15</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTNAME</design:name>
<design:position>2</design:position>
<design:precision>70</design:precision>
<design:uiHints>
<design:displayName>PRODUCTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTNAME</design:label>
<design:displaySize>70</design:displaySize>
<design:attributes>
<design:name>PRODUCTDESCRIPTION</design:name>
<design:position>3</design:position>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>PRODUCTDESCRIPTION</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTDESCRIPTION</design:label>
<design:displaySize>32700</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<list id="9">
<property name="dataSet">Q_SAMPLE</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression"
type="javascript">dataSetRow["PRODUCTCODE"]</expression>
</structure>
<structure>
type="javascript">dataSetRow["PRODUCTNAME"]</expression>
</structure>
<structure>
type="javascript">dataSetRow["PRODUCTDESCRIPTION"]</expression>
</structure>
</list-property>
<detail>
<grid id="10">
<property name="height">0.79375cm</property>
<property name="width">19.817291666666666cm</property>
<property name="pushDown">true</property>
<column id="11">
<property name="width">6.614583333333333cm</property>
</column>
<column id="12">
<property name="width">4.101041666666666cm</property>
</column>
<column id="13">
<property name="width">9.101666666666667cm</property>
</column>
<row id="14">
<cell id="15">
<data id="18">
<property name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="16">
<data id="19">
<property name="resultSetColumn">PRODUCTNAME</property>
</data>
</cell>
<cell id="17">
<data id="20">
<property name="resultSetColumn">PRODUCTDESCRIPTION</property>
</data>
</cell>
</row>
</grid>
</detail>
</list>
</body>
</report>
Am 16.11.2011 18:14, schrieb Jason Weathersby:
> Robert,
> Jason
>> Hi there,
>> 'overflow:visible'.
>> Thanks,
>> Robert
Re: Advanced Properties 'Inherited' in Layout-Hierarchies ? [message #757830 is a reply to message #757827] |
Wed, 16 November 2011 22:10 |
It should be pushing down the hierarchy inherited properties. Where
your other reports designed with an earlier version of BIRT?
Jason
On 11/16/2011 4:13 PM, Robert Aust wrote:
> Hi Jason,
> - pushdown : true
> just be cut off.
> Best regards,
> Robert
> id="1">
> <data-sources>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> PRODUCTDESCRIPTION
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:criteria/>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <list id="9">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <detail>
> <grid id="10">
> <column id="11">
> </column>
> <column id="12">
> </column>
> <column id="13">
> </column>
> <row id="14">
> <cell id="15">
> <data id="18">
> </data>
> </cell>
> <cell id="16">
> <data id="19">
> </data>
> </cell>
> <cell id="17">
> <data id="20">
> </data>
> </cell>
> </row>
> </grid>
> </detail>
> </list>
> </body>
> </report>
>> Robert,
>> Jason
>>> Hi there,
>>> 'overflow:visible'.
>>> Thanks,
>>> Robert
Re: Advanced Properties 'Inherited' in Layout-Hierarchies ? [message #757832 is a reply to message #757830] |
Thu, 17 November 2011 19:49 |
No - I have always been using 2.5.2
Maybe this was cause in my reports by other layout-changes, when I first
had (and later removed) fixed heights on some components etc.
In the sample reports I did none of that, just used the first/default
layout. I will keep an eye on that.
best regards,
Robert
Am 16.11.2011 23:10, schrieb Jason Weathersby:
> Jason
>> Hi Jason,
>> - pushdown : true
>> just be cut off.
>> Best regards,
>> Robert
>> <?xml version="1.0" encoding="UTF-8"?>
>> id="1">
>> <data-sources>
>> <property
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> PRODUCTDESCRIPTION
>> encoding="UTF-8"?>
>> <model:DesignValues
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> <design:criteria/>
>> ]]></xml-property>
>> </oda-data-set>
>> </data-sets>
>> <styles>
>> </style>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <list id="9">
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <detail>
>> <grid id="10">
>> <column id="11">
>> </column>
>> <column id="12">
>> </column>
>> <column id="13">
>> </column>
>> <row id="14">
>> <cell id="15">
>> <data id="18">
>> </data>
>> </cell>
>> <cell id="16">
>> <data id="19">
>> </data>
>> </cell>
>> <cell id="17">
>> <data id="20">
>> </data>
>> </cell>
>> </row>
>> </grid>
>> </detail>
>> </list>
>> </body>
>> </report>
>>> Robert,
>>> Jason
>>>> Hi there,
>>>> make it
>>>> 'overflow:visible'.
>>>> Thanks,
>>>> Robert
Current Time: Sat Apr 20 02:09:26 GMT 2024
Powered by FUDForum. Page generated in 0.03541 seconds
