headless Buckminster build fails with "Unbound classpath container" on OSX Lion [message #757771] |
Mon, 21 November 2011 15:25 |
Heribert Steuer Messages: 7 Registered: September 2010 |
trying to build an application with headless buckminster on osx lion fails with the following message:
Unbound classpath container: 'JRE System Library [JavaSE-1.6]'
the installed java version is:
java version "1.6.0_29"
Java(TM) SE Runtime Environment (build 1.6.0_29-b11-402-11M3527)
Java HotSpot(TM) 64-Bit Server VM (build 20.4-b02-402, mixed mode)
and should reflect the required version 1.6. I have set up the Java installation
(located at /Library/Java/JavaVirtualMachines/1.6.0_29-b11-402.jdk/Contents/Home/) as
an JRE in the Eclipse GUI without problems. So the jdk installation is fine and seems
to work well with Eclipse.
The very same project builds fine on linux, so the basic buckminster setup seems to be okay.
any hints where to dig deeper to solve this issue?
Heri
[Updated on: Mon, 21 November 2011 15:25] Report message to a moderator
FUDForum. Page generated in 0.02825 seconds
