Home » Modeling » TMF (Xtext) » Grammar problem (newbie)
Grammar problem (newbie) [message #757605] Sun, 20 November 2011 10:23 Go to next message
John Howard is currently offline John HowardFriend
Member
I have the following rule in a reasonably complex grammar that I am porting from ANTLR
BidPriority: PRIORITY priorityLevel=INT;
PRIORITY: 'p';
This matches p 1, but won't match p1.
Is there any way I can match p1?
Re: Grammar problem (newbie) [message #757607 is a reply to message #757605] Sun, 20 November 2011 10:38 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
i guess you have to use a terminal rule for this (plus a valueconverter that gives you the int part of the whole stuff)
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
BidPriority: priorityLevel=PRIORITY;
terminal PRIORITY returns ecore::EInt: 'p' ('0'..'9')+;
public class MyDslRuntimeModule extends org.xtext.example.mydsl2.AbstractMyDslRuntimeModule {
	public Class<? extends IValueConverterService> bindIValueConverterService() {
		return MyDslValueConverterService.class;
public class MyDslValueConverterService extends DefaultTerminalConverters {
	@ValueConverter(rule = "PRIORITY")
	public IValueConverter<Integer> PRIORITY() {
		return new IValueConverter<Integer>() {
			public Integer toValue(String string, INode node)
					throws ValueConverterException {
				return Integer.valueOf(string.substring(1));
			public String toString(Integer value)
				return "p" + value.toString();
if you want to use something like p1 at a place you would use and id
you have to introduce a datatype rule for this
Stuff: ID | PRIORITY;
stuff=Stuff
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
Re: Grammar problem (newbie) [message #757610 is a reply to message #757605] Sun, 20 November 2011 10:45 Go to previous messageGo to next message
Alexander Nittka is currently offline Alexander NittkaFriend
p1 is matched by the ID rule. It is hard to say what the best option would be for your use case. Possibly a data type rule with a value converter.
That way you would not have to introduce "unnecessary" keywords.
Bipriority: priorityLevel=Priority;
Priority returns ecore::EInt: ID;
And a value converter for Priority that throws a value conversion exception if the format is not p<Number> and extracts the number.
Alex
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext@itemis.de
Re: Grammar problem (newbie) [message #757814 is a reply to message #757610] Mon, 21 November 2011 19:22 Go to previous message
Member
Christian/Alex,
Many thanks for the replies - As I have control of the grammar I have decided to introduce a # so I can define the priority e.g. p#1 which I can manage through a terminal. However, it is good to know that I can revert back to my original syntax, which I may well do once I have got the grammar fully ported.
John
Previous Topic:understanding ImportManager
Next Topic:How i load resources dynamically
Current Time: Tue May 26 21:37:19 GMT 2020
Powered by FUDForum. Page generated in 0.01489 seconds
