Home » Newcomers » Newcomers » Installing Swing Designer, SWT Designer on Indigo -- JDK 1.7.0, Ubuntu(Installing Swing Designer, SWT Designer on Indigo -- JDK 1.7.0, Ubuntu)
Installing Swing Designer, SWT Designer on Indigo -- JDK 1.7.0, Ubuntu [message #757564] Sat, 19 November 2011 10:26
ramgorur  is currently offline ramgorur Friend
I am trying to install Swing/SWT designer in eclipse indigo. My machine is Ubuntu 10.10, running JDK 1.7.0 as default. I have added this url (h-t-t-p://download.eclipse.org/releases/indigo/) for eclipse software sources.
when I was trying to install Swing/SWT designer, the eclipse software installation wizard says --
Cannot complete the install because one or more required items could not be found.
Software currently installed: Shared profile 1.0.0.1308119049667 (SharedProfile_epp.package.java 1.0.0.1308119049667)
Missing requirement: Shared profile 1.0.0.1308119049667 (SharedProfile_epp.package.java 1.0.0.1308119049667) requires 'org.maven.ide.eclipse [1.0.0.20110607-2117]' but it could not be found
I am new with eclipse, what is maven? How do I install it? If I install maven, will the problem be solved?
Please help.
Previous Topic:Using WOlips and generated files not appearing in Sources Folder
Next Topic:Installing Struts 1.1 plugin in Eclipse Indigo
Current Time: Thu Jul 29 16:10:38 GMT 2021
Powered by FUDForum. Page generated in 0.02835 seconds
