Re: [Xpand] Questions regarding implementing MetaModelContributor [message #762270 is a reply to message #762262] |
Wed, 07 December 2011 19:38   |
Anders S Messages: 29 Registered: February 2011 |
Christian Dietrich wrote on Wed, 07 December 2011 14:22
is your metamodel class in the same project as the workflow?
No, the workflow is created in a running Eclipse instance.
Edit: an instance where the xpand metamodel is created
if not: does the defining plugin export the package with the metamodel?
Yes
does the workflow plugin have a bundle dep to the defining plugin or import the package?
It is included as dependency. I can successfully use the class when using Xpand without the workflow.
[Updated on: Wed, 07 December 2011 19:39] Report message to a moderator
FUDForum. Page generated in 0.03490 seconds
