Home » Modeling » TMF (Xtext) » GeneratorFragment refused to work
GeneratorFragment refused to work [message #757495] Fri, 18 November 2011 16:11 Go to next message
Tilo Thiele is currently offline Tilo ThieleFriend
Just another Newbie Question-
I tried to create a Generator and set im my .mwe file these properties to 'true':
          // generator API
            fragment = generator.GeneratorFragment {
                generateMwe = true
                generateJavaMain = true
But nothing happened. After debugging a while I noticed that this code fragment in the GeneratorFragment class
	public boolean isGenerateJavaMain(Grammar grammar) {
		if (XbaseGeneratorFragment.doesUseXbase(grammar)) {
			return false;
		return generateJavaMain;
prohibits what I expeced as my grammar uses xbase. What is the rationale behind this? How do I get a proper generator for a dsl which uses xbase?
Re: GeneratorFragment refused to work [message #757498 is a reply to message #757495] Fri, 18 November 2011 16:16 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
you are intended to write a jvmModelinferrer and then the generic JvmModelGenerator is used
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: GeneratorFragment refused to work [message #757500 is a reply to message #757498] Fri, 18 November 2011 16:30 Go to previous messageGo to next message
Ah - I see. I need to dive into this (new) concept. Thanks.
But there is a problem left. In my case I have a 'classic' persistence dsl describing also entites. So I want to generate Java source - by extending my PersistenceJvmModelInferrer - but I also need to generate sql-ddl code stuff. What is the best/right way to do so?
/Tilo
Re: GeneratorFragment refused to work [message #757503 is a reply to message #757500] Fri, 18 November 2011 16:35 Go to previous message
there are lots of possibilities
(1) write a complete own IGenerator and use XbaseCompiler within
(2) subclass JvmModelGenerator and overwrite _internalDoGenerate(EObject, IFilesystemaccess) method
(3) ....
in (1) and (2) add a binding for igenerator to the runtime module
~Christian
[Updated on: Fri, 18 November 2011 16:36]
Report message to a moderator
Previous Topic:Errors set in JavaValidator don't appear in the generation
Next Topic:compile Xtext programs
Current Time: Sat Apr 17 06:07:02 GMT 2021
Powered by FUDForum. Page generated in 0.02270 seconds
