Re: ClassNotFoundException when using bundled spring-context-support [message #757335 is a reply to message #757332] |
Thu, 17 November 2011 18:49 |
Dmitry Sklyut Messages: 279 Registered: January 2010 |
I don't think it has anything to do with spring imports/exports. You are doing Import-Library that will make all spring available for use. All classloading "should" be backed by your WAB Bundle.
I would still check that bundle classpath is properly setup and WEB-INF/lib jars are added to the Bundle-ClassPath manifest entry during transformation.
Can you also check what is the value of $VIRGO_HOME/repository/ext/org.eclipse.virgo.web.properties WABHeaders property. If it is "strict" - try to change it to "defaulted"
If that does not help: explicitly configure Bnd to add all of the WEB-INF/lib jar to the Bundle-ClassPath.
Bundle-ClassPath: .,/WEB-INF/lib/jar1.jar,/WEB-INF/lib/quartz.jar, etc
[Updated on: Thu, 17 November 2011 18:49] Report message to a moderator
FUDForum. Page generated in 0.03907 seconds
