Unable to create editor ID [message #757229] |
Thu, 17 November 2011 08:59 |
stefan Messages: 3 Registered: November 2011 |
it happened to me several times, that after some working with papyrus, it was no longer able to open the project. So far I have not noticed a pattern that lead to this problem.
Is this a known bug? How can the project be repaired? With the frequency this keeps happening to me this makes papyrus mostly unusable.
Every time the project is opened the following two exceptions are thrown.
Thanks for any help
Stefan
Exceptions:
eclipse.buildId=M20110909-1335
java.version=1.6.0_29
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.modeling.product -keyring /Users/saes/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.modeling.product -keyring /Users/saes/.eclipse_keyring -showlocation
Error
Thu Nov 17 09:26:16 CET 2011
Unable to create editor ID org.eclipse.papyrus.core.papyrusEditor: No Part found for the model 'org.eclipse.papyrus.sashwindows.di.impl.PageRefImpl@5158ce4 (objectPageIdentifier: null)'
java.lang.IllegalArgumentException: No Part found for the model 'org.eclipse.papyrus.sashwindows.di.impl.PageRefImpl@5158ce4 (objectPageIdentifier: null)'
at org.eclipse.papyrus.sasheditor.internal.SashWindowsContainer.createPagePart(SashWindowsContainer.java:275)
at org.eclipse.papyrus.sasheditor.internal.TabFolderPart.createChildPart(TabFolderPart.java:913)
at org.eclipse.papyrus.sasheditor.internal.TabFolderPart.createTabItem(TabFolderPart.java:842)
at org.eclipse.papyrus.sasheditor.internal.TabFolderPart.synchronize2(TabFolderPart.java:757)
at org.eclipse.papyrus.sasheditor.internal.RootPart.synchronize2(RootPart.java:139)
at org.eclipse.papyrus.sasheditor.internal.SashWindowsContainer.refreshTabsInternal(SashWindowsContainer.java:431)
at org.eclipse.papyrus.sasheditor.internal.SashWindowsContainer.refreshTabs(SashWindowsContainer.java:384)
at org.eclipse.papyrus.sasheditor.internal.SashWindowsContainer.createPartControl(SashWindowsContainer.java:173)
at org.eclipse.papyrus.sasheditor.editor.AbstractMultiPageSashEditor.createPartControl(AbstractMultiPageSashEditor.java:130)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2945)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.papyrus.onefile.providers.PapyrusModelActionProvider$1.run(PapyrusModelActionProvider.java:139)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
at org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:185)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:462)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4128)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3974)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3613)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Error
An unexpected exception was thrown.
at org.eclipse.papyrus.sasheditor.editor.AbstractMultiPageSashEditor.deactivate(AbstractMultiPageSashEditor.java:151)
at org.eclipse.papyrus.sasheditor.editor.AbstractMultiPageSashEditor.dispose(AbstractMultiPageSashEditor.java:162)
at org.eclipse.papyrus.core.editor.CoreMultiDiagramEditor.dispose(CoreMultiDiagramEditor.java:627)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:705)
Re: Unable to create editor ID [message #758931 is a reply to message #757229] |
Fri, 25 November 2011 10:41 |
Cedric Dumoulin Messages: 51 Registered: July 2009 |
Member |
Checking the provided model, it appears that there is no diagram
(.notation is empty) and that the .di file declare on open tabs, but
there is no reference to a diagram. This later can be explained by the
fact that the diagram is not present in .notation.
I suspect a problem when you save your model. It looks like the save
operation do not finish correctly, and that the diagram has not been saved.
Your uml model seem correct, but there is no more diagram.
When you save your model, check the progress green bar on the bottom
of Eclipse. If it still visible, the save doesn't complete correctly. In
this case, trying a saveAs can sometime help.
Can you confirm/infirm a problem while saving ?
Hope this help,
Cedric
stefan a écrit :
> Thanks for any help
> Stefan
> Exceptions:
> Error
> Unable to create editor ID org.eclipse.papyrus.core.papyrusEditor: No Part found for the model mailto:'org.eclipse.papyrus.sashwindows.di.impl.PageRefImpl@5158ce4 (objectPageIdentifier: null)'
> java.lang.IllegalArgumentException: No Part found for the model mailto:'org.eclipse.papyrus.sashwindows.di.impl.PageRefImpl@5158ce4 (objectPageIdentifier: null)'
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> Error
FUDForum. Page generated in 0.03104 seconds
