Problem Mapping Objects (RCP) [message #757217] |
Thu, 17 November 2011 07:45 |
Nack Gritt Messages: 8 Registered: November 2011 |
I am currently trying to create a test for some feature in Eclipse3.7(Indigo).
I am able to map every of its components necessary for the test except the Menus which in this case are:
- The main menus which are at the top most portion of the application (The ones that are labeled :'File', 'Edit', 'Source' ... all the way to 'Help')
- Every menus that appear when you right-click something, e.g. a treenode.
There are many of them and they are all cannot be collected by Jubula (there is no green border around them, either).
I am using the current Jubula1.1 and running it on Windows XP sp3, and I've also tried it with Eclipse 3.5 and Eclipse 3.6 which I ran into the exact same problem.
Any ideas?
Thank you in advance.
Nack.
[Updated on: Thu, 17 November 2011 07:57] Report message to a moderator
FUDForum. Page generated in 0.03601 seconds
