Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] "clear list" feature causes ConcurrentModificationException(Generated code seems invalid)
icon5.gif  [Texo] "clear list" feature causes ConcurrentModificationException [message #756811] Tue, 15 November 2011 08:56 Go to next message
R. Oldenburg is currently offline R. OldenburgFriend
don't know if I am using the latest Texo version (downloaded it approx. 1 month ago).
Will have a look at it.
So maybe this is already fixed.
The issue:
When generating bi-directional support for a ordered 1:n-relation then there are some generated features handling the changes that need to be applied to the "n"-list.
The method "clearXYZ" seems to be generated incorrectly as it:
- iterates over the list with an foreach (for XYZ xyz : XYZs)
- and calls "removeXYZ" for every entry (which handles the bi-directional remove)
This consequently leads to an ConcurrentModificationException because the list ( which it currently iterates on) is being modified (entries are removed).
Imo there are two possible solutions:
- Iterate over a copy of the org. list (i.e. for (XYZ xyz : new ArrayList<XYZ>(XYZs))
or
- simply remove the first entry from the list until it is empty
while (!XYZs.isEmpty()) {
 removeXYZ(XYZs.get(0));
Keep on the good work.
Thanks a lot for this tool and regards,
Roland
Re: [Texo] &quot;clear list&quot; feature causes ConcurrentModificationException [message #756863 is a reply to message #756811] Tue, 15 November 2011 11:35 Go to previous message
Martin Taal is currently offline Martin TaalFriend
Hi Roland,
Seems indeed like a bug, can you enter a bugzilla on Texo?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT&component=Texo&version=0.5
with the same description/text then I will pick it up.
gr. Martin
On 11/15/2011 09:56 AM, R. Oldenburg wrote:
> The issue:
> or
> Roland
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:Using EMF generated codes in external java codes
Next Topic:Duplicated ecore models !!
Current Time: Thu May 13 09:47:54 GMT 2021
Powered by FUDForum. Page generated in 0.01488 seconds
