Second GeneratorFragment [message #756072] |
Thu, 10 November 2011 19:11 |
Jens Missing name Messages: 27 Registered: November 2011 |
hi,
I have a problem with the second generator and I am getting a strange error message.
In the following I have posted some code to illustrate it (the error message is at the end of the posting).
package org.xtext.gui;
import org.xtext.gui.generator.GuiDslGeneratorAnother;
import com.google.inject.Guice;
import com.google.inject.Injector;
public class AnotherInjector extends GuiDslStandaloneSetup {
public Injector createInjector() {
return Guice.createInjector(new AnotherRuntimeModule());
public class AnotherRuntimeModule extends GuiDslRuntimeModule {
public Class<? extends org.eclipse.xtext.generator.IGenerator> bindIGenerator() {
return GuiDslGeneratorAnother.class;
My GuiDslGeneratorMWE.mwe2 in the generator package looks like this:
module org.xtext.gui.generator.GuiDslGeneratorMWE
import org.eclipse.emf.mwe.utils.*
var targetDir = "src-gen"
var modelPath = "dmodel"
Workflow {
component = org.eclipse.xtext.mwe.Reader {
// lookup all resources on the classpath
// useJavaClassPath = true
// or define search scope explicitly
path = modelPath
// this class will be generated by the xtext generator
register = org.xtext.gui.GuiDslStandaloneSetup {}
loadResource = {
slot = "model"
component = org.eclipse.xtext.generator.GeneratorComponent {
slot = 'model'
outlet = {
path = targetDir
In the generator package I have also created two xtend files:
GuiDslGenerator.xtend
GuiDslGeneratorAnother.xtend
But I am getting a strang error message now.
0 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems instantiating module org.xtext.gui.generator.GuiDslGeneratorMWE: java.lang.reflect.InvocationTargetException
java.lang.RuntimeException: Problems instantiating module org.xtext.gui.generator.GuiDslGeneratorMWE: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:90)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:73)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:64)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:55)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
I hope you can help me out.
regards,
jens.
[Updated on: Thu, 10 November 2011 19:12] Report message to a moderator
Re: Second GeneratorFragment [message #756245 is a reply to message #756088] |
Fri, 11 November 2011 16:27 |
hi,
sorry I don't know how to debug. I tried to keep it more simple.
So now I have only a console output in my generator file.
"run as" of the GuiDslGeneratorMWE.mwe2 file gives me the following response:
0 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
But there is no console output?
- System::out.println("Hello i'm the normal generator!");
package org.xtext.gui.generator
import org.eclipse.emf.ecore.resource.Resource
import org.eclipse.xtext.generator.IGenerator
import org.eclipse.xtext.generator.IFileSystemAccess
import org.eclipse.xtext.xbase.compiler.*
import org.eclipse.xtext.xbase.*
import org.eclipse.xtext.common.types.*
import com.google.inject.*
import org.xtext.gui.guiDsl.*
import java.util.*
import static extension org.eclipse.xtext.xtend2.lib.ResourceExtensions.*
import org.eclipse.xtext.naming.*
class GuiDslGenerator implements IGenerator {
@Inject extension IQualifiedNameProvider nameProvider
override void doGenerate(Resource resource, IFileSystemAccess fsa) {
package org.xtext.gui.generator.another
import java.util.*
class AnotherGenerator implements IGenerator {
System::out.println("Hello I'm another Generator!");
var modelPath = "model"
Workflow {
path = modelPath
loadResource = {
slot = "model"
slot = 'model'
outlet = {
path = targetDir
I have created a folder "model" in my workspace.
With the file "gui.mydsl"
package com.gui {
window win {
and so on..
regards,
jens
Even when I start a complete new project. I don't get the console output.
for(e: resource.allContentsIterable.filter(typeof(PackageDeclaration))) {
fsa.generateFile(
e.fullyQualifiedName.toString.replace(".", "/") + ".java",
e.compile)
How can I make sure, that the doGenerate-method is called?
[Updated on: Fri, 11 November 2011 19:21] Report message to a moderator
Re: Second GeneratorFragment [message #756291 is a reply to message #756245] |
Fri, 11 November 2011 19:31 |
here the steps for a new MyDsl Project
(1) create project with wizard and dont change anything and generate the language
(2) create a folder "model" in the runtimeproject and place a test.mydsl there
(3) change the generator workflow to
module org.xtext.example.mydsl.generator.MyDslGeneratorMWE
Workflow {
path = modelPath
register = org.xtext.example.mydsl.MyDslStandaloneSetup {}
loadResource = {
slot = "model"
slot = 'model'
outlet = {
path = targetDir
(4) change the generator itself to
package org.xtext.example.mydsl.generator
class MyDslGenerator implements IGenerator {
System::out.println("Hey here is the Generator")
(5) run the workflow
and it works
=> i think you dont read any model files.
did you place them in the right folder?
~Christian
Twitter : @chrdietrich
[Updated on: Fri, 11 November 2011 19:32] Report message to a moderator
Re: Second GeneratorFragment [message #756353 is a reply to message #756303] |
Sat, 12 November 2011 10:44 |
update of my post:
It works now, but only when the beautifier is not activated.
in the .xtend file:
System::out.println("Hey here is the Generator!!!!!!!!!!!")
fsa.generateFile(
e.fullyQualifiedName.toString.replace(".", "/") + "/Win" + ".java",
b.format(e.fullyQualifiedName.toString.replace(".", "/") + "/Win" + ".java",
e.compile))
package org.xtext.gui.dm.generator;
import java.io.File;
import org.eclipse.xpand2.output.FileHandle;
import org.eclipse.xpand2.output.FileHandleImpl;
import org.eclipse.xpand2.output.JavaBeautifier;
import org.eclipse.xpand2.output.Outlet;
import com.google.inject.Inject;
import com.google.inject.Singleton;
@Singleton
public class Beautifier {
@Inject
JavaBeautifier javaBeautifier;
* Format code with PostProcessor (XPand style).
public CharSequence format(String fileName, CharSequence code) {
// create fileHandle with dummy outlet.
File file = new File(fileName);
FileHandle fileHandle = new FileHandleImpl(new Outlet(), file);
fileHandle.setBuffer(code);
// call postProcessor for formatting the code.
javaBeautifier.beforeWriteAndClose(fileHandle);
// return formatted results.
return fileHandle.getBuffer();
With the activated beautifier I still get the error message:
1 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems instantiating module org.xtext.gui.dm.generator.GuiDslGeneratorMWE: java.lang.reflect.InvocationTargetException
java.lang.RuntimeException: Problems instantiating module org.xtext.gui.dm.generator.GuiDslGeneratorMWE: java.lang.reflect.InvocationTargetException
regards,
Jens
Re: Second GeneratorFragment [message #756381 is a reply to message #756364] |
Sat, 12 November 2011 14:08 |
hi,
here is my full stackstrace:
It seem that I don't have the necessary library installed.
org.eclipse.jface.text, org.eclipse.jdt.core, org.eclipse.core.runtime
is not accessable.
"java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException"
Caused by: org.eclipse.emf.common.util.WrappedException: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:56)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:137)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:112)
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalSwitch(Mwe2ExecutionEngine.java:64)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:136)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:78)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.create(Mwe2ExecutionEngine.java:60)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:88)
... 5 more
Caused by: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:54)
... 30 more
Caused by: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException
at com.google.inject.internal.MapMaker$StrategyImpl.compute(MapMaker.java:553)
at com.google.inject.internal.MapMaker$StrategyImpl.compute(MapMaker.java:419)
at com.google.inject.internal.CustomConcurrentHashMap$ComputingImpl.get(CustomConcurrentHashMap.java:2041)
at com.google.inject.internal.FailableCache.get(FailableCache.java:46)
at com.google.inject.ConstructorInjectorStore.get(ConstructorInjectorStore.java:52)
at com.google.inject.ConstructorBindingImpl.initialize(ConstructorBindingImpl.java:57)
at com.google.inject.InjectorImpl.initializeBinding(InjectorImpl.java:377)
at com.google.inject.InjectorImpl.createJustInTimeBinding(InjectorImpl.java:645)
at com.google.inject.InjectorImpl.createJustInTimeBindingRecursive(InjectorImpl.java:581)
at com.google.inject.InjectorImpl.getJustInTimeBinding(InjectorImpl.java:172)
at com.google.inject.InjectorImpl.getBindingOrThrow(InjectorImpl.java:132)
at com.google.inject.InjectorImpl.getInternalFactory(InjectorImpl.java:651)
at com.google.inject.FactoryProxy.notify(FactoryProxy.java:48)
at com.google.inject.BindingProcessor.runCreationListeners(BindingProcessor.java:230)
at com.google.inject.InjectorBuilder.initializeStatically(InjectorBuilder.java:131)
at com.google.inject.InjectorBuilder.build(InjectorBuilder.java:105)
at com.google.inject.Guice.createInjector(Guice.java:92)
at com.google.inject.Guice.createInjector(Guice.java:69)
at com.google.inject.Guice.createInjector(Guice.java:59)
at org.xtext.gui.dm.GuiDslStandaloneSetupGenerated.createInjector(GuiDslStandaloneSetupGenerated.java:26)
at org.xtext.gui.dm.GuiDslStandaloneSetupGenerated.createInjectorAndDoEMFRegistration(GuiDslStandaloneSetupGenerated.java:20)
at org.eclipse.xtext.mwe.AbstractReader.addRegister(AbstractReader.java:53)
... 35 more
Caused by: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException
at com.google.inject.MembersInjectorStore.get(MembersInjectorStore.java:66)
at com.google.inject.ConstructorInjectorStore.createConstructor(ConstructorInjectorStore.java:69)
at com.google.inject.ConstructorInjectorStore.access$000(ConstructorInjectorStore.java:31)
at com.google.inject.ConstructorInjectorStore$1.create(ConstructorInjectorStore.java:39)
at com.google.inject.ConstructorInjectorStore$1.create(ConstructorInjectorStore.java:35)
at com.google.inject.internal.FailableCache$1.apply(FailableCache.java:35)
at com.google.inject.internal.MapMaker$StrategyImpl.compute(MapMaker.java:549)
... 56 more
Caused by: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException
at com.google.inject.SingleFieldInjector.<init>(SingleFieldInjector.java:44)
at com.google.inject.MembersInjectorStore.getInjectors(MembersInjectorStore.java:113)
at com.google.inject.MembersInjectorStore.createWithListeners(MembersInjectorStore.java:83)
at com.google.inject.MembersInjectorStore.access$000(MembersInjectorStore.java:35)
at com.google.inject.MembersInjectorStore$1.create(MembersInjectorStore.java:43)
at com.google.inject.MembersInjectorStore$1.create(MembersInjectorStore.java:40)
... 66 more
Caused by: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException
... 85 more
Caused by: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException
... 95 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getDeclaredConstructors(Unknown Source)
at com.google.inject.spi.InjectionPoint.forConstructorOf(InjectionPoint.java:185)
at com.google.inject.ConstructorInjectorStore.createConstructor(ConstructorInjectorStore.java:61)
... 114 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.jface.text.BadLocationException
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
... 124 more
regards,
jens.
[Updated on: Sat, 12 November 2011 14:09] Report message to a moderator
FUDForum. Page generated in 0.03411 seconds
