how to execute two generators [message #755831] |
Wed, 09 November 2011 17:49  |
Jens Missing name Messages: 27 Registered: November 2011 |
hi,
I have two separate generator files (.xtend).
But I have only one ME2 Workflow file.
How can I execute them both with only one run.
I hope you can help me.
My idea was to create two separate mwe2 files. But
that's not a good solution.
regards,
jens
my mew2 file looks like this:
module org.xtext.gui.GenerateGuiDsl
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.generator.*
import org.eclipse.xtext.ui.generator.*
var grammarURI = "classpath:/org/xtext/gui/GuiDsl.xtext"
var file.extensions = "dmodel"
var projectName = "org.xtext.gui"
var runtimeProject = "../${projectName}"
Workflow {
bean = StandaloneSetup {
scanClassPath = true
platformUri = "${runtimeProject}/.."
component = DirectoryCleaner {
directory = "${runtimeProject}/src-gen"
directory = "${runtimeProject}.ui/src-gen"
component = Generator {
pathRtProject = runtimeProject
pathUiProject = "${runtimeProject}.ui"
pathTestProject = "${runtimeProject}.tests"
projectNameRt = projectName
projectNameUi = "${projectName}.ui"
language = {
uri = grammarURI
fileExtensions = file.extensions
// Java API to access grammar elements (required by several other fragments)
fragment = grammarAccess.GrammarAccessFragment {}
// generates Java API for the generated EPackages
fragment = ecore.EcoreGeneratorFragment {
// referencedGenModels = "
// platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel,
// platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel
// Serializer 2.0
fragment = serializer.SerializerFragment {}
// the serialization component (1.0)
// fragment = parseTreeConstructor.ParseTreeConstructorFragment {}
// a custom ResourceFactory for use with EMF
fragment = resourceFactory.ResourceFactoryFragment {
// The antlr parser generator fragment.
fragment = parser.antlr.XtextAntlrGeneratorFragment {
// options = {
// backtrack = true
// java-based API for validation
fragment = validation.JavaValidatorFragment {
composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
// scoping and exporting API
// fragment = scoping.ImportURIScopingFragment {}
// fragment = exporting.SimpleNamesFragment {}
fragment = scoping.ImportNamespacesScopingFragment {}
fragment = exporting.QualifiedNamesFragment {}
fragment = builder.BuilderIntegrationFragment {}
// generator API
fragment = generator.GeneratorFragment {
generateMwe = true
generateJavaMain = true
// formatter API
fragment = formatting.FormatterFragment {}
// labeling API
fragment = labeling.LabelProviderFragment {}
// outline API
fragment = outline.OutlineTreeProviderFragment {}
fragment = outline.QuickOutlineFragment {}
// quickfix API
fragment = quickfix.QuickfixProviderFragment {}
// content assist API
fragment = contentAssist.JavaBasedContentAssistFragment {}
// generates a more lightweight Antlr parser and lexer tailored for content assist
fragment = parser.antlr.XtextAntlrUiGeneratorFragment {}
// generates junit test support classes into Generator#pathTestProject
fragment = junit.Junit4Fragment {}
// project wizard (optional)
// fragment = projectWizard.SimpleProjectWizardFragment {
// generatorProjectName = "${projectName}"
// modelFileExtension = file.extensions
// provides the necessary bindings for java types integration
fragment = types.TypesGeneratorFragment {}
// generates the required bindings only if the grammar inherits from Xbase
fragment = xbase.XbaseGeneratorFragment {}
// provides a preference page for template proposals
fragment = templates.CodetemplatesGeneratorFragment {}
// rename refactoring
fragment = refactoring.RefactorElementNameFragment {}
// provides a compare view
fragment = compare.CompareFragment {
[Updated on: Wed, 09 November 2011 17:50] Report message to a moderator
FUDForum. Page generated in 0.03610 seconds
