Home » Newcomers » Newcomers » Eclipse java galileo win 32(Not Working with jre 1.6)
Eclipse java galileo win 32 [message #755680] Wed, 09 November 2011 10:04 Go to next message
Shobhit  is currently offline Shobhit Friend
I am installing eclipse-java-galileo-win32.zip on windows 2008 r2 with jre 1.6 latest update. But it says that 1.5 is required. Is it the problem or there is some other config issue? Any help would be highly appreciated.
Re: Eclipse java galileo win 32 [message #755682 is a reply to message #755680] Wed, 09 November 2011 10:05 Go to previous messageGo to next message
Also, If this version doesnt work with 1.6 then which version of eclipse java or jee can I use with 1.6 JRE?
Thanks.
Re: Eclipse java galileo win 32 [message #755717 is a reply to message #755682] Wed, 09 November 2011 11:28 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
I suggest to use the latest release. Go to
http://www.eclipse.org/downloads/ for it.
Dani
> Thanks.
Re: Eclipse java galileo win 32 [message #758348 is a reply to message #755680] Tue, 22 November 2011 20:55 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
Did you bother to look at the "sticky" topics at the top of this forum
group? One of the is titled "Trouble getting Eclipse to run? READ THIS
FIRST" and would probably help you.
On 11/9/11 5:04 AM, Shobhit wrote:
> appreciated.
> Thanks
Previous Topic:Class to hold DB Connections
Next Topic:Importing existing project into Eclipse
Current Time: Wed Jul 28 18:28:39 GMT 2021
Powered by FUDForum. Page generated in 0.02744 seconds
