Home » Modeling » TMF (Xtext) » [xtend2] import static inner Java classes
[xtend2] import static inner Java classes [message #755657] Wed, 09 November 2011 08:46 Go to next message
Hauke Fuhrmann is currently offline Hauke FuhrmannFriend
Hi there,
what's the syntax to access static inner Java classes in xtend2?
Does xtend support inner classes or do I have to wrap the inner class in
a normal class or something like that?
Rationale: I want to use EcoreUtil.UsageCrossReferencer in Xtend.
Hauke
Re: [xtend2] import static inner Java classes [message #755687 is a reply to message #755657] Wed, 09 November 2011 10:13 Go to previous messageGo to next message
Jan Koehnlein is currently offline Jan KoehnleinFriend
Static member access works with '::'
EcoreUtil::UsageCrossReferencer
System::out::println()
Am 09.11.11 09:46, schrieb Hauke Fuhrmann:
> Hi there,
> Cheers,
> Hauke
Get professional support from the Xtext committers at www.typefox.io
Re: [xtend2] import static inner Java classes [message #755688 is a reply to message #755687] Wed, 09 November 2011 10:17 Go to previous messageGo to next message
Oh sorry, of course println() is not static, so it's
System::out.println
Am 09.11.11 11:13, schrieb Jan Koehnlein:
>> Hi there,
>> Cheers,
>> Hauke
Re: [xtend2] import static inner Java classes [message #757877 is a reply to message #755687] Wed, 16 November 2011 13:44 Go to previous messageGo to next message
Hi Jan,
thanks, but I was *not* referring to static *members*, but static
*inner classes* like this in Java:
class MyClass{
static final class MyInnerClass{
In Xtend2 I now want to use MyInnerClass as a parameter for example.
def function(MyInnerClass it){
return it
I don't find any valid import syntax for this, like
import base.MyClass.MyInnerClass
or
import base.MyClass::MyInnerClass
In Java the first one works, in Xtend not.
Any clue? Is this not supported?
Hauke
Am 09.11.2011 11:13, schrieb Jan Koehnlein:
>> Hi there,
>> Cheers,
>> Hauke
Re: [xtend2] import static inner Java classes [message #757878 is a reply to message #757877] Wed, 16 November 2011 17:06 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Outer$Inner might work. Regards Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: [xtend2] import static inner Java classes [message #757880 is a reply to message #757878] Thu, 17 November 2011 12:43 Go to previous message
Am 16.11.2011 18:06, schrieb Christian Dietrich:
Yap, that works, thanks.
Hauke
Previous Topic:entity cross references in domainmodel
Next Topic:add external jar in xtext ui folder
Current Time: Wed Apr 21 21:58:35 GMT 2021
Powered by FUDForum. Page generated in 0.02373 seconds
