Re: DatabaseQuery - not possible to drop to Canvas [message #755871 is a reply to message #755648] |
Wed, 09 November 2011 22:09 |
Randy Childers Messages: 121 Registered: July 2009 |
Hi Wolfgang--
I'm sorry you were blocked by this, but I'm happy to say we've just
fixed the problem. If you're compiling from source, go ahead and update
now and you should be good to go. If you're using the VTP update site,
the update should be available for you tomorrow.
Thank you and good luck--
Randy
In <j9dctq$7m2$1@news.eclipse.org> fantasia1993 wrote:
> If i Drag and Drop a DatabaseQuery to Canvas, it disappears at the
> moment, when i drop it. If i save the Canvas later on, following Null-
> Pointer Exception appears in Eclipse: Paste it from Eclipse workspace: \.
> metadata\.log see logging below...
> Installed Components:
> - Java6
> - Eclipse V3.7.0
> - OpenVXML 4.0 (Installed by this Link inside Eclipse: /download.
> eclipse.org/technology/vtp/helios/
> Anyone else, that has the same Problem? Is it possible to use
> DatabaseQuery Modules in Open VXML 4.0?
> Thanks in advance for any ideas and comments!
> Wolfgang
> logging of Eclipse workspace: \.metadata\.log:
> !SESSION 2011-11-09 09:26:46.730 -----------------------------------------------
> eclipse.buildId=I20110613-1736
> java.version=1.6.0_24
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_AT
> Command-line arguments: -os win32 -ws win32 -arch x86
> !ENTRY org.eclipse.vtp.desktop.editors.core 4 0 2011-11-09 09:28:07.
> 632 !MESSAGE Could not save file: /VTP_WE_App/Workflow Design/Main
> Canvas.canvas !STACK 0 java.lang.NullPointerException at org.eclipse.
> vtp.desktop.model.elements.core.internal.PrimitiveElement.
> writeCustomConfiguration(PrimitiveElement.java:92) at org.eclipse.vtp.
> desktop.model.core.internal.DesignWriter.writeElementData(DesignWriter.
> java:104) at org.eclipse.vtp.desktop.model.core.internal.DesignWriter.
> writeDesign(DesignWriter.java:58) at org.eclipse.vtp.desktop.model.
> core.internal.DesignWriter.writeDesign(DesignWriter.java:30) at org.
> eclipse.vtp.desktop.model.core.internal.DesignDocument.
> commitWorkingCopy(DesignDocument.java:197) at org.eclipse.vtp.desktop.
> editors.core.impl.ApplicationEditor.doSave(ApplicationEditor.java:577)
> at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper.java:
> 151) at org.eclipse.ui.internal.SaveableHelper$5.run(SaveableHelper.
> java:277) at org.eclipse.jface.operation.ModalContext.
> runInCurrentThread(ModalContext.java:464) at org.eclipse.jface.
> operation.ModalContext.run(ModalContext.java:372) at org.eclipse.
> jface.window.ApplicationWindow$1.run(ApplicationWindow.java:759) at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWindow.
> java:756) at org.eclipse.ui.internal.WorkbenchWindow.run(
> WorkbenchWindow.java:2642) at org.eclipse.ui.internal.SaveableHelper.
> runProgressMonitorOperation(SaveableHelper.java:285) at org.eclipse.
> ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.
> java:264) at org.eclipse.ui.internal.SaveableHelper.savePart(
> SaveableHelper.java:156) at org.eclipse.ui.internal.EditorManager.
> savePart(EditorManager.java:1399) at org.eclipse.ui.internal.
> WorkbenchPage.savePart(WorkbenchPage.java:3416) at org.eclipse.ui.
> internal.WorkbenchPage.saveEditor(WorkbenchPage.java:3429) at org.
> eclipse.ui.internal.handlers.SaveHandler.execute(SaveHandler.java:54)
> at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.
> java:293) at org.eclipse.core.commands.Command.executeWithChecks(
> Command.java:476) at org.eclipse.core.commands.ParameterizedCommand.
> executeWithChecks(ParameterizedCommand.java:508) at org.eclipse.ui.
> internal.handlers.HandlerService.executeCommand(HandlerService.java:
> 169) at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeCommand(
> WorkbenchKeyboard.java:468) at org.eclipse.ui.internal.keys.
> WorkbenchKeyboard.press(WorkbenchKeyboard.java:786) at org.eclipse.ui.
> internal.keys.WorkbenchKeyboard.processKeyEvent(WorkbenchKeyboard.java:
> 885) at org.eclipse.ui.internal.keys.WorkbenchKeyboard.
> filterKeySequenceBindings(WorkbenchKeyboard.java:567) at org.eclipse.
> ui.internal.keys.WorkbenchKeyboard.access$3(WorkbenchKeyboard.java:508)
> at org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter.
> handleEvent(WorkbenchKeyboard.java:123) at org.eclipse.swt.widgets.
> EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.
> Display.filterEvent(Display.java:1262) at org.eclipse.swt.widgets.
> Widget.sendEvent(Widget.java:1052) at org.eclipse.swt.widgets.Widget.
> sendEvent(Widget.java:1077) at org.eclipse.swt.widgets.Widget.
> sendEvent(Widget.java:1062) at org.eclipse.swt.widgets.Widget.
> sendKeyEvent(Widget.java:1104) at org.eclipse.swt.widgets.Widget.
> sendKeyEvent(Widget.java:1100) at org.eclipse.swt.widgets.Widget.
> wmChar(Widget.java:1509) at org.eclipse.swt.widgets.Control.WM_CHAR(
> Control.java:4640) at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.
> java:345) at org.eclipse.swt.widgets.Control.windowProc(Control.java:
> 4528) at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
> at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972) at
> org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method) at
> org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2530) at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752) at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660) at
> org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494) at
> org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674) at org.
> eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:
> 332) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(
> Workbench.java:667) at org.eclipse.ui.PlatformUI.
> createAndRunWorkbench(PlatformUI.java:149) at org.eclipse.ui.internal.
> ide.application.IDEApplication.start(IDEApplication.java:123) at org.
> eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.
> java:196) at org.eclipse.core.runtime.internal.adaptor.
> EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.
> eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(
> EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.
> EclipseStarter.run(EclipseStarter.java:344) at org.eclipse.core.
> runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) at sun.
> reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.
> reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:
> 39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(
> DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.
> invoke(Method.java:597) at org.eclipse.equinox.launcher.Main.
> invokeFramework(Main.java:622) at org.eclipse.equinox.launcher.Main.
> basicRun(Main.java:577) at org.eclipse.equinox.launcher.Main.run(Main.
> java:1410)
FUDForum. Page generated in 0.02479 seconds
