PCL + cmake : Compiles Fine, but errors while in the path [SOLVED] [message #755517] |
Tue, 08 November 2011 16:59 |
boulch Mising name Messages: 2 Registered: November 2011 |
I currently use CDT with cmake to build a Point Cloud Library (PCL) project.
Here is my CMakeLists :
cmake_minimum_required(VERSION 2.
PROJECT( project_name )
set(EXECUTABLE_NAME executable)
add_executable(
#executable
${EXECUTABLE_NAME}
#libraries
IOCloud.h
Ply.hpp
#source code
main.cpp
Ply.cpp
set(CMAKE_BUILD_TYPE Release)
set(CMAKE_MODULE_PATH ${CMAKE_MODULE_PATH})
include_directories( ${CMAKE_CURRENT_BINARY_DIR})
#packages
#PointCloud Library
find_package( PCL 1.1 REQUIRED)
if(PCL_FOUND)
include_directories( ${PCL_INCLUDE_DIRS} )
link_directories( ${PCL_LIBRARY_DIRS} )
add_definitions( ${PCL_DEFINITIONS} )
target_link_libraries(
${EXECUTABLE_NAME}
${PCL_COMMON_LIBRARIES}
${PCL_IO_LIBRARIES}
${PCL_LIBRARIES}
endif()
#OpenMp
find_package( OpenMP REQUIRED)
#include(FindOpenMP)
if(OPENMP_FOUND)
set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} ${OpenMP_C_FLAGS}")
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} ${OpenMP_CXX_FLAGS}")
set(CMAKE_EXE_LINKER_FLAGS "${CMAKE_EXE_LINKER_FLAGS} ${OpenMP_EXE_LINKER_FLAGS}")
endif()
I'm running Eclipse 3.7.1 on Ubuntu 11.10
The project imported in Eclipse, compiles and runs fine.
The PCL libraries are in the include Path.
The completion works for #include <pcl/...
But all the pcl objects and function can't be resolved (red underline and "could not be resolved" message).
It looks like it doesn't know the namespace.
Can anyone help me ?
Thanks.
[Updated on: Mon, 29 July 2013 08:52] Report message to a moderator
FUDForum. Page generated in 0.04516 seconds
