Re: [Xtext 2.1] Problems extending Xbase [message #755939 is a reply to message #755822] |
Thu, 10 November 2011 09:25 |
Goran Messages: 45 Registered: November 2011 |
Member |
Sebastian,
I tried the nightly build however I still got the same problem.
Could it be that I didn't do the update correctly?
From a fresh eclipse-SDK-3.7.1-Xtext-2.1.0-linux-gtk-x86_64 distribution I did:
- Install New Software
- Add
- Choose the downloaded nightly build archive tmf-xtext-Update-N201111081203.zip
- select the "TMF Xtext" and on Next it says that an update will be done
- Next, Finish, etc
Still the problem with the same grammar.
Thanks in advance
[Updated on: Thu, 10 November 2011 09:26] Report message to a moderator
Re: [Xtext 2.1] Problems extending Xbase [message #756005 is a reply to message #755957] |
Thu, 10 November 2011 13:04 |
Member |
Thanks Sebastian,
I updated and indeed the problem went away for the XVariableDeclaration rule.
However I still get the same error for the name feature when using the following rule in an extension of Xbase:
FullJvmFormalParameter returns jvmTypes::JvmFormalParameter:
{FullJvmFormalParameter} final ?= 'final'? parameterType=JvmTypeReference name=ValidID;
~Goran
[Updated on: Thu, 10 November 2011 13:05] Report message to a moderator
FUDForum. Page generated in 0.03684 seconds
