ComponentNotFoundException [message #755305] |
Tue, 08 November 2011 03:19 |
Ning Wang Messages: 10 Registered: July 2011 |
I get this exception, any idea what might be wrong? Many thanks for your help.
org.eclipse.jubula.rc.common.exception.ComponentNotFoundException: unmanaged component with identifier: 'org.eclipse.jubula.tools.objects.ComponentIdentifier@8deb03a[component type=org.eclipse.swt.widgets.Tree,alternative name=<null>,hierarchy=[org.eclipse.swt.widgets.Shell_1, org.eclipse.swt.widgets.Shell_1, org.eclipse.swt.widgets.Composite_1, org.eclipse.swt.widgets.Composite_1, org.eclipse.swt.widgets.Composite_1, org.eclipse.swt.widgets.Composite_1, org.eclipse.swt.widgets.Composite_1, org.eclipse.swt.widgets.Composite_1, org.eclipse.swt.widgets.Composite_1, org.eclipse.ui.dialogs.FilteredTree_1, org.eclipse.swt.widgets.Composite_2, org.eclipse.swt.widgets.Tree_1]]'.
at org.eclipse.jubula.rc.swt.listener.ComponentHandler.findComponent(ComponentHandler.java:195) ~[org.eclipse.jubula.rc.swt.jar:na]
at org.eclipse.jubula.rc.swt.commands.CAPTestCommand.findComponent(CAPTestCommand.java:43) ~[org.eclipse.jubula.rc.swt.jar:na]
at org.eclipse.jubula.rc.common.commands.AbstractCapTestCommand.getImplClass(AbstractCapTestCommand.java:130) [org.eclipse.jubula.rc.common.jar:na]
at org.eclipse.jubula.rc.common.commands.AbstractCapTestCommand.execute(AbstractCapTestCommand.java:225) [org.eclipse.jubula.rc.common.jar:na]
at org.eclipse.jubula.communication.Communicator$ConnectionListener.received(Communicator.java:845) [org.eclipse.jubula.communication.jar:na]
at org.eclipse.jubula.communication.connection.Connection.fireMessageReceived(Connection.java:402) [org.eclipse.jubula.communication.jar:na]
at org.eclipse.jubula.communication.connection.Connection.access$3(Connection.java:391) [org.eclipse.jubula.communication.jar:na]
at org.eclipse.jubula.communication.connection.Connection$ReaderThread.run(Connection.java:454) [org.eclipse.jubula.communication.jar:na]
Re: ComponentNotFoundException [message #755842 is a reply to message #755325] |
Wed, 09 November 2011 19:05 |
Hi Alex,
First, I want to thank you guys for this excellent work. The error was caught during running the test in headless model with xvfb configuration. I cannot reproduce the problem any more. But I do get another issue, here are the use cases.
The AUT is "eclipse + our plugin"
1. If I launch AUT through testexec with -autconfig, the test runs ok.
2. If I launch AUT through autrun, I get a lot of NPE. The client.log is attached.
Please let me know if you need extra information.
OS: Fedora 13 x64
Jubula: 1.1.0
Db: Embedded H2
Another question, can I build indigo_sr1_rc4 and install as a plugin? If yes, I can help to do trouble shooting and probably submit patchs.
Ning
[Updated on: Thu, 10 November 2011 07:58] Report message to a moderator
FUDForum. Page generated in 0.03379 seconds
