Re: Gradle : Bundlor plugin in Groovy [message #755487 is a reply to message #754611] |
Tue, 08 November 2011 16:13 |
So the Gradle plugin should extend the Java plugin that comes with Gradle and just overwrite the Manifest step. The main entry point in to Bundlor is the ManifestGenerator Class. I'd have a look at the 'org.eclipse.virgo.bundlor.ant.internal.AntBundlorExecutor' Class in the Ant plugin and see how it does things. You should just be able to copy code really, depends exactly what the Gradle SPI looks like.
Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Re: Gradle : Bundlor plugin in Groovy [message #757025 is a reply to message #757022] |
Wed, 16 November 2011 06:26 |
The latest Bundlor is pointing at 3.0.1.RELEASE but we need to ship another milestone of Bundlor to get that out. I recommend building against the very latest of Bundlor in the GIT repo and then you will find all your dependencies are present in the Maven repo. Let me know if you need it to be published in maven and I'll do another milestone for you.
Chris.
Re: Gradle : Bundlor plugin in Groovy [message #781094 is a reply to message #757443] |
Fri, 20 January 2012 14:12 |
How did you get on with this, it would be great if you would be willing to donate your plugin so others can use it?
Chris.
FUDForum. Page generated in 0.02922 seconds
