Home » Eclipse Projects » BPMN 2.0 Modeler » BPMN2 Modeler now available for Helios
BPMN2 Modeler now available for Helios [message #754508] Wed, 02 November 2011 19:51 Go to next message
Robert Brodt is currently offline Robert BrodtFriend
Hi all,
The BPMN2 Modeler is now available for download for both eclipse 3.6 (Helios) and 3.7 (Indigo).
The Helios build can be found at:
http://download.eclipse.org/bpmn2-modeler/site-helios/
The Indigo and most recent build can be downloaded from:
http://download.eclipse.org/bpmn2-modeler/site/
Cheers!
Bob
Re: BPMN2 Modeler now available for Helios [message #760502 is a reply to message #754508] Fri, 02 December 2011 15:10 Go to previous messageGo to next message
Michael Mocx is currently offline Michael MocxFriend
I tried the following
- downloaded a Eclipse 3.6 Helios "Eclipse IDE for SOA Developers"
- Install New Software "BPMN2 Editor" from //download.eclipse.org/bpmn2-modeler/site-helios/
- I got a warning while installing: "...contains unsigned content..."
- after restarting Eclipse I created a new project
- File - New - Other - (Select Wizard) BPMN2 - BPMN2 Diagram
- After Finish the Diagram window opens but with exceptions...
at org.eclipse.bpmn2.modeler.core.runtime.TargetRuntime.getRuntime(TargetRuntime.java:79)
at org.eclipse.bpmn2.modeler.core.preferences.Bpmn2Preferences.load(Bpmn2Preferences.java:77)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.loadPreferences(BPMN2Editor.java:199)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.init(BPMN2Editor.java:163)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1254)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1207)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1606)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:497)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:483)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2860)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2674)
at org.eclipse.bpmn2.modeler.ui.wizards.BPMN2DiagramCreator$1.run(BPMN2DiagramCreator.java:87)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:388)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1008)
at org.eclipse.bpmn2.modeler.ui.wizards.BPMN2DiagramWizard.performFinish(BPMN2DiagramWizard.java:89)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:254)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:274)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Greatings
Michael
[Updated on: Fri, 02 December 2011 15:10]
Report message to a moderator
Re: BPMN2 Modeler now available for Helios [message #899484 is a reply to message #760502] Wed, 01 August 2012 06:59 Go to previous messageGo to next message
liu guihai is currently offline liu guihaiFriend
I checked out the bpmn2 modeler source from git(git://git.eclipse.org/gitroot/bpmn2-modeler/org.eclipse.bpmn2-modeler.git),and then I got the binary one from eclipse update site(http://download.eclipse.org/bpmn2-modeler/site).
However I find the source one containg :
org.eclipse.bpmn2.modeler.runtime.jboss.jbpm
and the binary one containg:
org.eclipse.bpmn2.modeler.core_0.0.1.201207272032.jar
org.eclipse.bpmn2.modeler.runtime.jboss.jbpm5_0.0.1.201207272032.jar
org.eclipse.bpmn2.modeler.ui_0.0.1.201207272032.jar
org.eclipse.bpmn2_0.7.0.201207181605.jar
org.eclipse.bpmn2.editor_0.7.0.201207181605.jar
org.eclipse.bpmn2.edit_0.7.0.201207181605.jar
So how can I get the source code for the last three:bpmn2、bpmn2.editor、bpmn2.edit?
Re: BPMN2 Modeler now available for Helios [message #899710 is a reply to message #899484] Thu, 02 August 2012 04:18 Go to previous messageGo to next message
I find the project for the last three:git://git.eclipse.org/gitroot/bpmn2
[Updated on: Thu, 02 August 2012 05:23]
Re: BPMN2 Modeler now available for Helios [message #899738 is a reply to message #899710] Thu, 02 August 2012 07:29 Go to previous message
The github shadows can be out of date with respect to the git repo
maintained at Eclipse: http://git.eclipse.org/c/bpmn2/
On 02/08/2012 6:18 AM, liu guihai wrote:
> When I pasted the url I got,the forum complained:
> You can only use links to eclipse.org sites while you have fewer than
> 25 messages.
> so I spit it as follows:
> https:
> github.com/eclipse/bpmn2.git.
> Is that always actvie?
Ed Merks
Previous Topic:Welcome to eclipse.bpmn2-modeler
Next Topic:Question about the org.eclipse.bpmn2.modeler.runtime extension point
Current Time: Thu Jul 16 14:37:39 GMT 2020
Powered by FUDForum. Page generated in 0.01896 seconds
