Home » Modeling » M2T (model-to-text transformation) » [Acceleo] .mtl or .emtl?
[Acceleo] .mtl or .emtl? [message #753952] Mon, 31 October 2011 07:10 Go to next message
Harri T. is currently offline Harri T.Friend
For some reason I can't generate Java classes from a UML model anymore. I have generateJava.mtl (not .emtl) and this far it's been working ok. Now launching Acceleo run configuration in Eclipse does nothing and the error below is dumped into workspace/.metadata/.log.
What should I do to get Acceleo working again?
Harri
!ENTRY org.eclipse.acceleo.ide.ui 4 0 2011-10-31 08:59:45.145
!MESSAGE '/myacceleo/generateJava.emtl' not found
!STACK 0
java.io.IOException: '/myacceleo/generateJava.emtl' not found
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.initialize(AbstractAcceleoGenerator.java:437)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoLaunchOperation.run(AcceleoLaunchOperation.java:123)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2326)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginLaunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java:225)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginLaunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java:128)
at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchDelegate.launch(AcceleoLaunchDelegate.java:51)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:854)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:928)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1132)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Re: [Acceleo] .mtl or .emtl? [message #754750 is a reply to message #753952] Fri, 04 November 2011 07:59 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
Hi Harri,
".mtl" files are the Acceleo modules as you type them, ".emtl" are the compiled couterparts of these files which Acceleo works with. You should never have to worry about ".emtl" resources : Acceleo compiles them itself and they are not in a folder you should look into Wink (bin folder).
The error message you get is a symptom of Acceleo not being able to compile the module you try and launch. Do you have the automatic build activated (Project > build automatically)? Is your "mtl" module in a source folder? Is your project an Acceleo project? Does it work when you force a build (project > clean, select "clean all")?
Laurent Goubet
Obeo
Re: [Acceleo] .mtl or .emtl? [message #757873 is a reply to message #754750] Sat, 19 November 2011 17:29 Go to previous message
Hi Laurent
Cleaning the project having .mtl helped. Thanks!
Harri
On 4.11.2011 9:59 Laurent Goubet wrote:
> Hi Harri,
> ".mtl" files are the Acceleo modules as you type them, ".emtl" are the compiled couterparts of these files which Acceleo works with. You should never have to worry about ".emtl" resources : Acceleo compiles them itself and they are not in a folder you should look into ;) (bin folder).
> Laurent Goubet
> Obeo
Previous Topic:Java Model Exception when executing Xtend functions
Next Topic:Beginner needs a helping hand either on jet or acceleo to process ecore model
Current Time: Sat Feb 27 03:42:45 GMT 2021
Powered by FUDForum. Page generated in 0.02251 seconds
