Home » Eclipse Projects » EGit / JGit » How to configure default merge strategy?
How to configure default merge strategy? [message #753901] Sun, 30 October 2011 12:39 Go to next message
Martin Fluegge is currently offline Martin FlueggeFriend
I committed two changes to my "master" and then pulled from the remote repository. After this operation pushing was prohibited because the merge operation during the pull was not able to merge the changes (see attached images). I found out that egit per default uses "resolve" as merge strategy. Trying a "merge" on the git bash was able to merge the different changes because it was using "recursiv" as merge strategy.
Is there a way to change the default merge strategy egit uses?
Thanks in advance.
Martin
Re: How to configure default merge strategy? [message #753913 is a reply to message #753901] Sun, 30 October 2011 14:46 Go to previous messageGo to next message
Robin Rosenberg is currently offline Robin RosenbergFriend
Martin Fluegge skrev 2011-10-30 13.3925:
At the moment EGit does not have the recursive merge strategy. The reason
is that initially we did not have rename detection. Now, we do. so adding
the recursive merge should be fairly simple.
-- robin
Re: How to configure default merge strategy? [message #753921 is a reply to message #753913] Sun, 30 October 2011 15:40 Go to previous messageGo to next message
Hi Robin,
thanks for your quick response. Shall I file a bugzilla for this topic?
Martin
Am 30.10.2011 15:46, schrieb Robin Rosenberg:
>> Hi,
> -- robin
Re: How to configure default merge strategy? [message #753926 is a reply to message #753921] Sun, 30 October 2011 17:08 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 30.10.2011 16:40, schrieb Martin Fl├╝gge:
> Hi Robin,
I found this: https://bugs.eclipse.org/bugs/show_bug.cgi?id=354099
Cheers
/Eike
http://www.esc-net.de
> Cheers,
> Martin
>>> Hi,
>> -- robin
Re: How to configure default merge strategy? [message #756143 is a reply to message #753926] Fri, 11 November 2011 08:45 Go to previous messageGo to next message
Sylvain Laurent is currently offline Sylvain LaurentFriend
Is recursive merge strategy planned for 1.2.0 ? it would really help to handle merges with renamed files.
Re: How to configure default merge strategy? [message #756178 is a reply to message #756143] Fri, 11 November 2011 12:01 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
1.2 is planned for Dec 15 and I am not aware that anyone is currently working on this
Re: How to configure default merge strategy? [message #760795 is a reply to message #753901] Mon, 05 December 2011 10:02 Go to previous message
Andre Dietisheim is currently offline Andre DietisheimFriend
Just to add some more pointers to this topic: the bugzilla that I guess is watching the progress on the recursive merging strategy (which should handle merging better than the resolve strategy) is here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=359951
Previous Topic:gui nit in history view
Next Topic:Staging view shows unchanged files
Current Time: Wed Jun 03 04:44:51 GMT 2020
Powered by FUDForum. Page generated in 0.02433 seconds
