Home » Eclipse Projects » JFace » List folders and files with Tree/TreeView with JFace
List folders and files with Tree/TreeView with JFace [message #753816] Fri, 28 October 2011 23:11 Go to next message
Zé  arlos is currently offline Zé arlosFriend
Now I am developing a sample plugin for Eclipse, to show all directories and files from my computer, using JFace (Tree and TreeView).
I want something like this:
| Element | Number of Childrens |
| + usr | 5 |
| + bin | 4 |
| file | |
| + games | 2 |
I create the plugin View witch ViewPart, the ContentProvider and the TreeLabelProvider.
public class ListFiles extends ViewPart {
    /** The ID of the view as specified by the extension. */
    public static final String ID = "sortnumbers.views.SortNumbers";
     * The constructor.
    public ListFiles() { }
     * This is a callback that will allow us to create the viewer and initialize it
    public void createPartControl(Composite parent) {
        Tree tree = new Tree(parent, SWT.MULTI);
        tree.setHeaderVisible(true);
        tree.setLinesVisible(true);
        TreeColumn column0 = new TreeColumn(tree, SWT.NONE);
        column0.setText("Element");
        column0.setWidth(300);
        TreeColumn column1 = new TreeColumn(tree, SWT.NONE);
        column1.setText("Number");
        column1.setWidth(300);
        TreeViewer treeviewer = new TreeViewer(tree);
        treeviewer.setContentProvider(new TreeContentProvider());
        treeviewer.setLabelProvider(new TreeLabelProvider());
        treeviewer.setInput(new FolderNode(new File("/")));
    public void setFocus() {
        // TODO
public class TreeContentProvider implements ITreeContentProvider
    public Object[] getChildren(Object parentElement) {
        return ((ITreeNode)parentElement).getChildren().toArray();
    public Object getParent(Object element) {
        return ((ITreeNode)element).getParent();
    public boolean hasChildren(Object element) {
        return ((ITreeNode)element).hasChildren();
    public Object[] getElements(Object inputElement) {
        return getChildren(inputElement);
    public void dispose() {
    public void inputChanged(Viewer viewer, Object oldInput, Object newInput) {
public class TreeLabelProvider extends LabelProvider
    public String getText(Object element) {
        return ((ITreeNode)element).getName();
To search for all Files in my computer I create the interface ITreeNode, TreeNode, FolderNode and FileNode...
public interface ITreeNode
    public String getName();
    public List getChildren();
    public boolean hasChildren();
    public ITreeNode getParent();
public abstract class TreeNode implements ITreeNode
    protected ITreeNode fParent;
    protected List fChildren;
    public TreeNode(ITreeNode parent) {
        fParent = parent;
    public boolean hasChildren() {
        return true;
    public ITreeNode getParent() {
        return fParent;
        if( fChildren != null )
            return fChildren;
        fChildren = new ArrayList();
        createChildren(fChildren);
        return fChildren;
    /* subclasses should override this method and add the child nodes */
    protected abstract void createChildren(List children);
public class FolderNode extends TreeNode
    private File fFolder; /* actual data object */
    public FolderNode(File folder) {
        this(null, folder);
    public FolderNode(ITreeNode parent, File folder) {
        super(parent);
        fFolder = folder;
    public String getName() {
        return "FOLDER: " + fFolder.getName();
    protected void createChildren(List children)
        File[] childFiles = fFolder.listFiles();
        for(int i=0; i<childFiles.length; i++)
            File childFile = childFiles[i];
            if( childFile.isDirectory() )
                children.add(new FolderNode(this, childFile));
            else
                children.add(new FileNode(this, childFile));
public class FileNode extends TreeNode
    private File fFile; /* actual data object */
    public FileNode(ITreeNode parent, File file)
        super(parent);
        fFile = file;
        return "FILE: " + fFile.getName();
    protected void createChildren(List children) {
        return false;
But the result was:
| + usr | + usr |
| + bin | + bin |
| file | file |
| + games | + games |
I cannot understand why TreeView fill all fields with the same string... What I need to change? Confused
Thanks in advance Smile
Re: List folders and files with Tree/TreeView with JFace [message #753845 is a reply to message #753816] Sat, 29 October 2011 10:42 Go to previous messageGo to next message
I need to change the class TreeLabelProvider to this:
public class TreeLabelProvider extends BaseLabelProvider implements ITableLabelProvider
	public Image getColumnImage(Object element, int columnIndex) {
		return null;
	public String getColumnText(Object element, int columnIndex) {
		if (columnIndex == 0)
        else
            return Integer.toString(((ITreeNode)element).getChildren().size());
---8<---
And about sorting the TreeViewer?! Rolling Eyes Should I create a Class witch extended ViewerComparator or ViewerSorter? And how can I implement the method compare to sort elements in the TreeViewer?
Thanks in advance
Re: List folders and files with Tree/TreeView with JFace [message #754003 is a reply to message #753845] Mon, 31 October 2011 11:46 Go to previous message
Ok, after a couple of hours, I found the solution for this topic...
A TreeViewer with a Tree witch list the files and dir of your PC, with two columns 'Element' and 'Number of Files in a dir'... You can sort the Tree cliking in a column...
ListFiles
	public static final String ID = "sortnumbers.views.ListFiles";
	protected static final int COLUMN_ELEMENT = 0;
	protected static final int COLUMN_NUMBER = 1;
	private TreeViewer treeviewer;
	private Tree tree;
	private TreeColumn column0;
	private TreeColumn column1;
	private TreeSorter sorter = new TreeSorter(this);
	 * The constructor.
		sorter.addColumn(column0, COLUMN_ELEMENT);
		sorter.addColumn(column1, COLUMN_NUMBER);
		TreeColumn sortColumn = null;
		switch (sorter.getSortColumn())
			case COLUMN_ELEMENT:
				sortColumn = column0;
				break;
			case COLUMN_NUMBER:
				sortColumn = column1;
				break;
		sorter.setSortColumnAndDirection(sortColumn, sorter.isReverseSort() ? SWT.DOWN : SWT.UP);
		treeviewer.setComparator(sorter);
		treeviewer.setInput(new FolderNode(new File("/home/zecarlos/Documents/Teste/")));
	protected void refreshViewer() {
		treeviewer.refresh();
		// empty
ITreeNode
TreeNode
	protected String number;
		fParent = parent;
		return true;
		return fParent;
			return fChildren;
		return fChildren;
FolderNode
		this(null, folder);
		super(parent);
		fFolder = folder;
		return fFolder.getName();
			else
				children.add(new FileNode(this, childFile.getName()));
FileNode
	private String name; /* actual data object */
	public FileNode(ITreeNode parent, String name) {
		super(parent);
		this.name = name;
		return this.name;
		// empty
		return false;
TreeContentProvider
TreeLabelProvider
		return null;
        else
TreeSorter
public class TreeSorter extends ViewerComparator
	private final ListFiles view;
	private final ViewerComparator elementsorter = new JavaElementComparator();
	private int sortcolumn;
	private boolean reversesort;
	public TreeSorter(ListFiles view) {
		this.view = view;
	void addColumn(final TreeColumn column, final int columnidx)
		column.addSelectionListener(new SelectionListener()
			public void widgetSelected(SelectionEvent e)
				toggleSortColumn(columnidx);
				setSortColumnAndDirection(column, isReverseSort() ? SWT.DOWN : SWT.UP);
				view.refreshViewer();
			public void widgetDefaultSelected(SelectionEvent e) { }
	void setSortColumnAndDirection(TreeColumn sortColumn, int direction) {
		sortColumn.getParent().setSortColumn(sortColumn);
		sortColumn.getParent().setSortDirection(direction);
	public int getSortColumn() {
		return sortcolumn;
	public boolean isReverseSort() {
		return reversesort;
	public void toggleSortColumn(int column) {
		if (sortcolumn == column) {
			reversesort = !reversesort;
		else {
			reversesort = false;
			sortcolumn = column;
	public int compare(Viewer viewer, Object e1, Object e2)
		ITreeNode node1 = (ITreeNode) e1;
		ITreeNode node2 = (ITreeNode) e2;
		int res = 0;
		switch (getSortColumn())
			case ListFiles.COLUMN_ELEMENT:
				res = node1.getName().compareTo(node2.getName());
				break;
			case ListFiles.COLUMN_NUMBER:
				res = (int) (node1.getChildren().size() - node2.getChildren().size());
				break;
		if (res == 0)
			res = elementsorter.compare(viewer, e1, e2);
		else
			res = isReverseSort() ? -res : res;
		return res;
Cheers, Very Happy
Previous Topic:[Databinding] JSR-303 support for JFace Databinding Validators
Next Topic:SourceViewer undo support
Current Time: Tue Apr 16 11:30:00 GMT 2024
Powered by FUDForum. Page generated in 0.09050 seconds
