Home » Newcomers » Newcomers » Cannot import SWT Plug in (HelloWorldSWT tutorial)
Cannot import SWT Plug in (HelloWorldSWT tutorial) [message #753001] Wed, 26 October 2011 11:48 Go to next message
OK, first of all: I am new to everything: programming, java, and eclipse.
I downloaded the Java SKD, installed, then downloaded Eclipes Java IDE (for Win64, running in Win7-64x), "installed" it, and ran it.
First thing: tutorials. I did the "Hello World" Tutorial with no problems. Then I go to the Hello World SWT tutorial. There I found this:
The tutorial (cheat sheet) tells me to Import the SWT project. To do that, I should open the import wizard (File>Import...) and there pick Plug-in Development>Plug-ins and Fragments.
Well: there is not such an option. I tried the "Click to perform" option within the cheat sheet, but only get a "The command did not complete successfully", with this in its details:
The command did not complete successfully.
unknown wizard: org.eclipse.pde.ui.PluginImportWizard
It seems to me weird since I am just following the included tutorial, but I have not found a way to get around it (the file that I should import, org.eclipse.swt.{platform}.{os}.{arch} (for example: org.eclipse.swt.win32.win32.x86 for win32) is in a plug-in folder inside the eclipse folder (it's a .jar file). But I don't know what option I should use to successfully import it (otherwise, when I get to further steps in the tutorial, "Configure the Java project", I don't have the proper options to pick).
Thanks in advance, and I am sorry if this question is really silly.
Re: Cannot import SWT Plug in (HelloWorldSWT tutorial) [message #753364 is a reply to message #753001] Wed, 26 October 2011 16:48 Go to previous messageGo to next message
I think you need to download the Eclipse for RCP and RAP developers.
P.S.: Normally your example should work but the menu "Plug-in development" doesn't exist in the Eclipse IDE for Java Developers (which I believe is the one that you downloaded), so... it doesn't work.
Re: Cannot import SWT Plug in (HelloWorldSWT tutorial) [message #753572 is a reply to message #753364] Thu, 27 October 2011 16:01 Go to previous messageGo to next message
Thanks! Ok, I'll try downloading the version you recommend me!
Re: Cannot import SWT Plug in (HelloWorldSWT tutorial) [message #753978 is a reply to message #753001] Mon, 31 October 2011 06:38 Go to previous messageGo to next message
please take notice, that the SWT toolkit has to be downloaded before and that the newest IDE is a little bit different.
for more info:
www.eclipse.org/swt/
Claus
Re: Cannot import SWT Plug in (HelloWorldSWT tutorial) [message #809527 is a reply to message #753001] Tue, 28 February 2012 19:46 Go to previous messageGo to next message
I had exactly the same problem and found the steps on the following page worked for me:
www.eclipsepluginsite.com/swt.html
Hope this helps.
Re: Cannot import SWT Plug in (HelloWorldSWT tutorial) [message #871627 is a reply to message #753001] Mon, 14 May 2012 11:00 Go to previous messageGo to next message
Help -> Install New Software
Work with: --All Available Sites--
General Purpose Tools -> Eclipse Plug-in Development Environment
[Finish]
After installing this plug-in and restarting Eclipse, you will be able to proceed with the tutorial.
Re: Cannot import SWT Plug in (HelloWorldSWT tutorial) [message #995683 is a reply to message #871627] Sun, 30 December 2012 16:44 Go to previous messageGo to next message
Thank You Richard!
Your solution solved my problem lickety split.
From the Main Menu->[Help]->"Install New Software". This launches the "Install" dialog. Click the down arrow on the "Work With" drop down box and choose "--All Available Sites--", which populates the list box right below. Find and check "Eclipse Plug-in Development Environment" - click [Next], accept the terms, etc. then [Finish]
Problem solve
Re: Cannot import SWT Plug in (HelloWorldSWT tutorial) [message #1234023 is a reply to message #995683] Mon, 20 January 2014 22:32 Go to previous messageGo to next message
hi
I can´t find this option, please help e
in spanish
no puedo encontrar esas opciones en el ambiente
Re: Cannot import SWT Plug in (HelloWorldSWT tutorial) [message #1710913 is a reply to message #871627] Sat, 10 October 2015 15:57 Go to previous messageGo to next message
Very Happy Perfect! what a wonderful tip!
I am new so this was very helpful, thanks!
Re: Cannot import SWT Plug in (HelloWorldSWT tutorial) [message #1710914 is a reply to message #753001] Sat, 10 October 2015 16:12 Go to previous message
Eclipse Lunar under the Tutorials actually has steps how to create an Eclipse Plug-in. Richard's tip was awesome!
Previous Topic:Override Eclipse Command
Next Topic:FrameworkEvent ERROR for Mars
Current Time: Tue May 13 21:37:26 EDT 2025
Powered by FUDForum. Page generated in 0.17245 seconds
