Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo+Hibernate]Help! A hibernate mapping question
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #84453 is a reply to message #84440] |
Tue, 22 May 2007 09:09   |
Anthony,
Model refers to one instance of Network and one instance of OptimizedResult and you want the
features of Network and OptimizedResult to be mapped to the same table as Model. When a Model is
saved also the Network and OptimizedResult are saved.
Is this what you want?
gr. Martin
Anthony wrote:
> Martin,
> Thank you for help.
> I just learn to write my mapping file.
> It seems that when a new persistable object was saved
> a new record will be inserted into its mapped table.
> In my case, the sample structure of my EMF model list below:
> Model
> |____Network
> |____OptimizedResult
> There is a table called T_Model which will store all the attribute in
> Model,Netwrok and OptimizedResult.
> So I cannot map 3 classes into T_Model.
> But I am not sure if it is possible to map into DB View.
> Regards,
> Anthony
>> Hi Anthony,
>> I think you mean embedded but to be sure can you give a small example
>> of what you want to achieve?
>> gr. Martin
>> Anthony wrote:
>>> Hi,
>>> I have several classes in a EMF model and these classes will be
>>> mapped
>>> into ONE table . How to write the mapping file to only let one class
>>> to insert/update/delete the table record and the others just mapped
>>> to some fields?
>>> Thanks in advance!
>>> Anthony
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #84479 is a reply to message #84465] |
Tue, 22 May 2007 09:21   |
Anthony,
To achieve this you can set the @Embedded annotation in the ereferences Model.Network and
Model.OptimizedResult.
If there are nameclashes between Network, OptimizedResult and Model then you can use
@AttributeOverrides.
gr. Martin
Anthony wrote:
> Martin,
> Exactly.
> Anthony
>> Anthony,
>> OptimizedResult and you want the features of Network and
>> is saved also the Network and OptimizedResult are saved.
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Thank you for help.
>>> Model
>>> |____Network
>>> |____OptimizedResult
>>> in
>>> Regards,
>>> Anthony
>>>> Hi Anthony,
>>>> example of what you want to achieve?
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Hi,
>>>>> mapped
>>>>> class to insert/update/delete the table record and the others just
>>>>> mapped to some fields?
>>>>> Thanks in advance!
>>>>> Anthony
The Netherlands
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #84489 is a reply to message #84479] |
Tue, 22 May 2007 10:02   |
Anthony Lee Messages: 114 Registered: July 2009 |
Martin,
OK. I will try it.
I have another question :
In my case ,the model structure list as below:
Network
|________ProductCatalog
| |_______Product collection
|________CustomerCatlog
|_______Customer collection
When UI want to show product collections,
the ProductCatalog object will act as collection's
parent object to avoid getting customer collecitons.
(If no ***catalog, ContentProvider will return Network's children)
Do I have to have table to mapped ***Catalog class?
Anthony
> Anthony,
> ereferences Model.Network and Model.OptimizedResult.
> then you can use @AttributeOverrides.
> gr. Martin
> Anthony wrote:
>> Martin,
>> Exactly.
>> Anthony
>>> Anthony,
>>> Model is saved also the Network and OptimizedResult are saved.
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>>>> Thank you for help.
>>>> Model
>>>> |____Network
>>>> |____OptimizedResult
>>>> attribute in
>>>> Regards,
>>>> Anthony
>>>>> Hi Anthony,
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Hi,
>>>>>> mapped
>>>>>> just mapped to some fields?
>>>>>> Thanks in advance!
>>>>>> Anthony
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #84501 is a reply to message #84489] |
Tue, 22 May 2007 10:10  |
Anthony,
You can try to set @Embedded also on Network.ProductCatalog/CustomerCatalog to get it into the same
table as Model and Network. Is that whay you want/mean?
gr. Martin
Anthony wrote:
> Martin,
> OK. I will try it.
> Network
> Anthony
>> Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Exactly.
>>> Anthony
>>>> Anthony,
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Martin,
>>>>> Thank you for help.
>>>>> Model
>>>>> |____Network
>>>>> |____OptimizedResult
>>>>> attribute in
>>>>> Regards,
>>>>> Anthony
>>>>>> Hi Anthony,
>>>>>> gr. Martin
>>>>>> Anthony wrote:
>>>>>>> Hi,
>>>>>>> mapped
>>>>>>> Thanks in advance!
>>>>>>> Anthony
The Netherlands
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #606760 is a reply to message #84440] |
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> Thank you for help.
> Model
> |____Network
> |____OptimizedResult
> Regards,
> Anthony
>> Hi Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Hi,
>>> mapped
>>> to some fields?
>>> Thanks in advance!
>>> Anthony
The Netherlands
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #606762 is a reply to message #84465] |
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> Exactly.
> Anthony
>> Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Thank you for help.
>>> Model
>>> |____Network
>>> |____OptimizedResult
>>> in
>>> Regards,
>>> Anthony
>>>> Hi Anthony,
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Hi,
>>>>> mapped
>>>>> Thanks in advance!
>>>>> Anthony
The Netherlands
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #606763 is a reply to message #84479] |
Martin,
OK. I will try it.
Network
Anthony
> Anthony,
> gr. Martin
> Anthony wrote:
>> Martin,
>> Exactly.
>> Anthony
>>> Anthony,
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>>>> Thank you for help.
>>>> Model
>>>> |____Network
>>>> |____OptimizedResult
>>>> attribute in
>>>> Regards,
>>>> Anthony
>>>>> Hi Anthony,
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Hi,
>>>>>> mapped
>>>>>> Thanks in advance!
>>>>>> Anthony
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #606764 is a reply to message #84489] |
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> OK. I will try it.
> Network
> Anthony
>> Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Exactly.
>>> Anthony
>>>> Anthony,
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Martin,
>>>>> Thank you for help.
>>>>> Model
>>>>> |____Network
>>>>> |____OptimizedResult
>>>>> attribute in
>>>>> Regards,
>>>>> Anthony
>>>>>> Hi Anthony,
>>>>>> gr. Martin
>>>>>> Anthony wrote:
>>>>>>> Hi,
>>>>>>> mapped
>>>>>>> Thanks in advance!
>>>>>>> Anthony
The Netherlands
Current Time: Sat Jan 28 21:20:41 GMT 2023
Powered by FUDForum. Page generated in 0.05063 seconds
