Home » Archived » M2M (model-to-model transformation) » [ATL] Programmaticaly launch transformation involving UML models
[ATL] Programmaticaly launch transformation involving UML models [message #84331] Wed, 11 June 2008 13:43 Go to next message
Originally posted by: karp.no-mail.com
I'm trying to write a small transformation involving UML2 models.
I have no problem to launch it through the atl perspective. I use
"uri:http://www.eclipse.org/uml2/2.1.0/UML" as the uri of the UML metamodel.
But I haven't managed to lauch it programmaticaly (I have no problem for
standard non-UML models).
My atl transformation is like that, very simple :
----------------------8<------------------------
module SimpleUMLNoProfile; -- Module Template
create B : UML from A : UML;
rule Model {
from
s : UML!"uml::Model"
to
t : UML!"uml::Model"
---------------------8<-------------------------
My model in input is like that : (basically a model, a package, a class)
<uml:Model xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML"
xmi:id="_eGIhADeTEd2OqNGrMp5Krw" name="ModelA">
<packageImport xmi:id="_eGIhATeTEd2OqNGrMp5Krw">
<importedPackage xmi:type="uml:Model"
href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"/>
</packageImport>
<packagedElement xmi:type="uml:Package"
xmi:id="_qbq6UDeTEd2OqNGrMp5Krw" name="PackageA">
<packagedElement xmi:type="uml:Class"
xmi:id="_snfRoDeTEd2OqNGrMp5Krw" name="ClassA">
<ownedAttribute xmi:id="_usVeQDeTEd2OqNGrMp5Krw" name="PropertyA"
isUnique="false">
<type xmi:type="uml:PrimitiveType"
href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
</ownedAttribute>
</packagedElement>
</packagedElement>
<profileApplication xmi:id="_eGIhAjeTEd2OqNGrMp5Krw">
<eAnnotations xmi:id="_eGIhAzeTEd2OqNGrMp5Krw"
source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage"
href=" pathmap://UML_PROFILES/Standard.profile.uml#_yzU58YinEdqtvbn fB2L_5w"/>
</eAnnotations>
<appliedProfile href="pathmap://UML_PROFILES/Standard.profile.uml#_0"/>
</profileApplication>
</uml:Model>
--------------------8<-----------------------------
My code...
AtlModelHandler amh = null;
amh = new AtlUML2ModelHandler();
URL urlTransfo = null;
try { urlTransfo = asmFile.toURI().toURL();
} catch (MalformedURLException e) {}
Map<String, ASMModel> mapASMModels = new HashMap<String, ASMModel>();
ResourceSet resourceSet = AtlEMFModelHandler.getResourceSet();
resourceSet.getPackageRegistry().put("http://www.eclipse.org/uml2/2.1.0/UML",
UMLPackage.eINSTANCE);
URI uri =
URI.createURI(" jar:file:/D:/eclipse/eclipse-modeling-ganymede-RC1-win32/ATL _LIBS_RC3/org.eclipse.uml2.uml.resources_2.2.0.v200805131030 .jar!/ ");
resourceSet.getURIConverter().URI_MAP.put(URI.createURI(UMLR esource.LIBRARIES_PATHMAP),
uri.appendSegment("libraries").appendSegment(""));
resourceSet.getURIConverter().URI_MAP.put(URI.createURI(UMLR esource.METAMODELS_PATHMAP),
uri.appendSegment("metamodels").appendSegment(""));
resourceSet.getURIConverter().URI_MAP.put(URI.createURI(UMLR esource.PROFILES_PATHMAP),
uri.appendSegment("profiles").appendSegment(""));
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);
ASMModel asmUML = ((AtlEMFModelHandler)amh).loadModel("UML",
amh.getMof(), "uri:http://www.eclipse.org/uml2/2.1.0/UML");
File fileA = new File(PATH + "ModelA.uml");
InputStream inA = null;
try { inA = fileA.toURI().toURL().openStream();
} catch (MalformedURLException e) {} catch (IOException e) {}
ASMModel asmA;
asmA = amh.loadModel("A", asmUML, inA);
File fileB = new File(PATH + "ModelB.uml");
InputStream inB = null;
try {inB = fileB.toURI().toURL().openStream();
ASMModel asmB = amh.loadModel("B", asmUML, inB);
mapASMModels.put("A", asmA);
mapASMModels.put("B", asmB);
mapASMModels.put("UML", asmUML);
Map params = Collections.EMPTY_MAP; // Parameters
Map<String, URL> mapLibs = new HashMap<String, URL>();
// Launch ATL transformation
AtlLauncher.getDefault().launch(urlTransfo, mapLibs, mapASMModels,
params,
Collections.EMPTY_LIST, Collections.EMPTY_MAP);
And now the error : (sorry for the length)
11 juin 2008 15:10:11 org.eclipse.m2m.atl.engine.vm.SimpleDebugger error
GRAVE: ****** BEGIN Stack Trace
GRAVE: exception:
GRAVE: argument type mismatch
java.lang.IllegalArgumentException: argument type mismatch
at
org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:69)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:338)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
at
at
at
at
at
at
at
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
at UmlAtlLaunch.transfoRegularVM(UmlAtlLaunch.java:86)
at UmlAtlTest.main(UmlAtlTest.java:9)
11 juin 2008 15:10:11 org.eclipse.m2m.atl.engine.vm.ExecEnv printStackTrace
GRAVE: A.main() : ??#22 null
GRAVE: local variables = {self=SimpleUMLNoProfile : ASMModule}
GRAVE: local stack = []
GRAVE: A.__matcher__() : ??#1 null
GRAVE: A.__matchModel() : ??#35 null
GRAVE: local variables = {s=A!ModelA, self=SimpleUMLNoProfile : ASMModule}
GRAVE: local stack = [TransientLinkSet {}]
GRAVE: NativeOperation public static void
org.eclipse.m2m.atl.engine.vm.nativelib.ASMTransientLink.add TargetElement(org.eclipse.m2m.atl.engine.vm.StackFrame,org.e clipse.m2m.atl.engine.vm.nativelib.ASMTransientLink,org.ecli pse.m2m.atl.engine.vm.nativelib.ASMString,org.eclipse.m2m.at l.engine.vm.nativelib.ASMOclAny)
GRAVE: args = [TransientLink {rule = 'Model', sourceElements = {s =
A!ModelA}, targetElements = {}, variables = {}}, TransientLink {rule =
'Model', sourceElements = {s = A!ModelA}, targetElements = {}, variables
= {}}, 't']
GRAVE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to
allow continuation after errors).
11 juin 2008 15:10:11 org.eclipse.m2m.atl.engine.AtlLauncher launch
GRAVE: null
java.lang.RuntimeException
at
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:195)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:95)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:87)
at
org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:74)
at
at
at
at
at
at
at
at
at
at
at
Caused by: java.lang.IllegalArgumentException: argument type mismatch
at
... 19 more
Re: [ATL] Programmaticaly launch transformation involving UML models [message #84346 is a reply to message #84331] Wed, 11 June 2008 16:02 Go to previous messageGo to next message
By the way if someone could upload a sample project where he manages to
launch programmaticaly an ATL transformation using UML models that'd be
awesome.
Re: [ATL] Programmaticaly launch transformation involving UML models [message #84359 is a reply to message #84331] Wed, 11 June 2008 16:50 Go to previous messageGo to next message
neto Mising name is currently offline neto Mising nameFriend
Member
your transfomation is create B : UML from A : UML;
so, the model A must be a InputStream but the B must be a OutputStream,
and the ASMModel need be a newModel, dont a loadModel.
Netuh
karp wrote:
> rule Model {
> from
> to
> </packageImport>
> isUnique="false">
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </eAnnotations>
> </uml:Model>
> My code...
> URI uri =
> ASMModel asmA;
> params,
> GRAVE: exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> = {}}, 't']
> GRAVE: null
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Re: [ATL] Programmaticaly launch transformation involving UML models [message #84374 is a reply to message #84359] Thu, 12 June 2008 07:05 Go to previous message
It was a stupid mistake of mine.
Thanks for letting me see it.
Netuh has written :
> Netuh
> karp wrote:
>> Hi,
>> metamodel.
>> for standard non-UML models).
>> rule Model {
>> from
>> to
>> <?xml version="1.0" encoding="UTF-8"?>
>> </packageImport>
>> name="PropertyA" isUnique="false">
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </eAnnotations>
>> <appliedProfile
>> </uml:Model>
>> My code...
>> ASMModel>();
>> URI uri =
>> ASMModel asmA;
>> mapASMModels, params,
>> GRAVE: exception:
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> printStackTrace
>> printStackTrace
>> printStackTrace
>> printStackTrace
>> printStackTrace
>> printStackTrace
>> printStackTrace
>> printStackTrace
>> ASMModule}
>> printStackTrace
>> printStackTrace
>> printStackTrace
>> = A!ModelA}, targetElements = {}, variables = {}}, TransientLink {rule
>> = 'Model', sourceElements = {s = A!ModelA}, targetElements = {},
>> variables = {}}, 't']
>> GRAVE: null
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 19 more
Previous Topic:Re: [ATL][UML] set stereotyped tagged value
Next Topic:[ATL] random crashes?
Current Time: Sun Aug 25 08:04:45 GMT 2019
Powered by FUDForum. Page generated in 0.02900 seconds
