Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Saving an Ecore Miodel
[Teneo] Saving an Ecore Miodel [message #83862] |
Thu, 17 May 2007 19:50 |
Originally posted by: irbull.cs.uvic.ca
Martin,
I think I have found a way to improve my performance problems by
changing my model. I was trying to put a bunch of different data models
into 1 database (using a normalized form), however, it works much better
if I save the different data models in separate databases.
However, this approach requires me to save both my Ecore model and my
instance data using Teneo. The instance data saving works no problem,
however, when I save my Ecore model, the etype of my references and
attributes don't seem to get saved. This this a known issue?
All I am doing is setting my hdbs.setEPackages to
EcorePackage.eInstance, and then saving my package.
Do I have to do something different to save the etypes?
Thanks for all your help,
Ian
Re: [Teneo] Saving an Ecore Miodel [message #83891 is a reply to message #83862] |
Fri, 18 May 2007 04:17 |
Ian,
The cause could be that you maybe miss this epackage:
XMLTypePackage.eINSTANCE
You should pass both this xmltype epackage, the ecorepackage and your application model epackages to
the hbds.
gr. Martin
Ian Bull wrote:
> Martin,
> Ian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Saving an Ecore Miodel [message #84096 is a reply to message #83891] |
Fri, 18 May 2007 20:33 |
You're right, I did miss the XMLTypePackage. However, it still seems to
be giving me some errors. I don't really understand why I need to pass
my application model as a package to the hbds. I am trying to save my
application model to the database, so therefore don't I just need to
pass the MetaModel for my application model (which is Ecore and
XMLTypePackage).
I tried to pass my application model package to hbds too, but that still
didn't work. My code is now just:
<code>
DatabaseCreate.setupTeneo(hbds, dbMetaModelName, new EPackage[] {
XMLTypePackage.eINSTANCE, EcorePackage.eINSTANCE });
Session session = hbds.getSessionFactory().openSession();
Transaction tx = session.getTransaction();
tx.begin();
session.save( <<THE EPACKAGE FOR MY MODEL>> );
tx.commit();
System.out.println("Finished saving meta-model");
</code>
Then when I load this back, I get the EPackage, then I set the epackage
in hbds and try and load the instance I get the following NPE:
Exception in thread "main" java.lang.NullPointerException
at
org.eclipse.emf.teneo.ERuntime.computeContainedClasses(ERunt ime.java:141)
at org.eclipse.emf.teneo.ERuntime.register(ERuntime.java:99)
at
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.ma p(DefaultAnnotator.java:192)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:128)
at
org.eclipse.emf.teneo.hibernate.HbDataStore.mapEPackages(HbD ataStore.java:531)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionDataStore.java:149)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:70)
at viewrecommender.ecore.DatabaseCreate.setupTeneo(DatabaseCrea te.java:37)
at viewrecommender.ecore.DatabaseAccess.main(DatabaseAccess.jav a:107)
I looked at the mappings that were generated and it seems that the
TypedElement is not actually saving its type:
it is only saving its:
epackage,
ordered,
unique,
lowerBound
upperBound
Thanks again,
Ian
Martin Taal wrote:
> Ian,
> application model epackages to the hbds.
> gr. Martin
> Ian Bull wrote:
>> Martin,
>> models into 1 database (using a normalized form), however, it works
>> much better if I save the different data models in separate databases.
>> Ian
Re: [Teneo] Saving an Ecore Miodel [message #606723 is a reply to message #83862] |
Ian,
the hbds.
gr. Martin
Ian Bull wrote:
> Martin,
> Ian
The Netherlands
Re: [Teneo] Saving an Ecore Miodel [message #606737 is a reply to message #83891] |
Ian Bull Messages: 145 Registered: July 2009 |
XMLTypePackage).
<code>
tx.begin();
tx.commit();
</code>
at
at
at
at
at
at
epackage,
ordered,
unique,
lowerBound
upperBound
Thanks again,
Ian
Martin Taal wrote:
> Ian,
> gr. Martin
> Ian Bull wrote:
>> Martin,
>> Ian
Current Time: Thu Apr 25 09:17:09 GMT 2024
Powered by FUDForum. Page generated in 0.04376 seconds
