Home » Archived » M2M (model-to-model transformation) » [QVT XSD EMF] How to get a xsd complexType from a model
[QVT XSD EMF] How to get a xsd complexType from a model [message #83721] Thu, 05 June 2008 19:03 Go to next message
Originally posted by: David-392.Li.MorganStanley.com
I tried to get a xsd complex type from a model, but failed.
The .qvto is as following:
modeltype INTEROP uses "http://www.test.com/interop";
modeltype XSD uses "http://www.eclipse.org/xsd/2002/XSD";
transformation interop2xsd(in interop: INTEROP , out XSD);
main(in interopModel: INTEROP::InteropSchema, out xsd: XSD::XSDSchema) {
xsd:= interopModel.map interop2Xsd();
mapping INTEROP::InteropSchema::interop2Xsd() : XSD::XSDSchema {
targetNamespace := 'http://www.test.com/schedule';
typeDefinitions := self.views2Types();
query INTEROP::InteropSchema::views2Types() :
OrderedSet(XSD::XSDTypeDefinition) {
self.views->collect(view | view.view2Type())->asOrderedSet();
mapping INTEROP::InteropViewComplexType::view2Type() :
XSD::XSDComplexTypeDefinition
{ -- only set name, no others since I even can not get a complex type
name := self.name;
The IN parameter:
<?xml version="1.0" encoding="ISO-8859-1"?>
<interop:InteropSchema xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:interop="http://ms.com/interop"
domainName="interoptest" schemaMetaMajorVersion="1"
schemaMetaMinorVersion="4">
<views name="Schedule" version="1">
<elements name="scheduleId" maxOccurs="1" minOccurs="1"
type="xsd:string"/>
<elements name="price" maxOccurs="1" minOccurs="0" type="xsd:double"/>
</views>
</interop:InteropSchema>
However, the OUT is as follows:
<schema targetNamespace='http://www.test.com/schedule'/>
The problems are:
1) There is no xmlns:xsd="http://www.w3.org/2001/XMLSchema", how can I
get this generated?
2) Why I can not get a complex type with 'Schedule' named? Do I have to
set more attributes? Since XSD.ecore is quit complex, I am not sure how to
do mapping exactly? Is there any good example?
Thanks for any suggestions.
David
Re: [QVT XSD EMF] How to get a xsd complexType from a model [message #83767 is a reply to message #83721] Fri, 06 June 2008 13:51 Go to previous messageGo to next message
Radomil Dvorak is currently offline Radomil DvorakFriend
Hi David,
You should not set your complex type to 'typeDefinitions' as it's not a =
containment reference
and will not get serialized along with the XSDSchema instance
>> typeDefinitions :=3D self.views2Types();
You can easily figure out by hyperlink navigation from 'typeDefinitions'=
into the metamodel
browser and check the properties.
Unfortunately, I'm not an expert on XSDSchema metamodel, but I think the=
complex types should
go to 'XSDSchema::contents'. By doing so you will face another problem, =
which is NPE from
the XSDSchema metamodel, due to getQNamePrefixToNamespaceMap() not =
initialized with neccessary stuff.
Both 1) and 2) seem connected to this.
So apparently, a deeper knowledge of XSDSchema will be needed.
I'm not aware of any good example about this but just an idea ;-),
you might have a look at org.eclipse.xsd.ecore.EcoreSchemaBuilder.java,
which produces an XSDSchema from an Ecore EPackage.
Just a small comment on your main(...), no need to have args there.
It is still supported as it came with the original contribution of Borla=
nd =
QVT.
This kind of manifested the concrete types required by the entry point t=
o =
clients,
however, what you create as the output model goes automatically to the =
output extent
and is saved to the resource assigned in your launch config.
If you name your out model param explicitly like bellow
transformation interop2xsd(in interop: INTEROP , out xsdOut : XSD);
you can refer to it in object instantiations and send it to the right pl=
ace
in case of multiple outputs.
Sorry, I have not solved your problem...
/Radek
On Thu, 05 Jun 2008 21:03:19 +0200, David <David-392.Li@MorganStanley.co=
m> =
wrote:
> I tried to get a xsd complex type from a model, but failed. The .qvto =
is =
> as following:
> main(in interopModel: INTEROP::InteropSchema, out xsd: XSD::XSDSchema)=
> xsd:=3D interopModel.map interop2Xsd();
> targetNamespace :=3D 'http://www.test.com/schedule';
> query INTEROP::InteropSchema::views2Types() : =
> mapping INTEROP::InteropViewComplexType::view2Type() : =
> { -- only set name, no others since I even can not get a complex =
> type name :=3D self.name;
> The IN parameter:
> <?xml version=3D"1.0" encoding=3D"ISO-8859-1"?>
> <interop:InteropSchema xmi:version=3D"2.0" =
> xmlns:xmi=3D"http://www.omg.org/XMI" xmlns:interop=3D"http://ms.com/in=
terop" =
> domainName=3D"interoptest" schemaMetaMajorVersion=3D"1" =
> schemaMetaMinorVersion=3D"4">
> <views name=3D"Schedule" version=3D"1">
> <elements name=3D"scheduleId" maxOccurs=3D"1" minOccurs=3D"1" =
> type=3D"xsd:string"/>
> <elements name=3D"price" maxOccurs=3D"1" minOccurs=3D"0" =
> type=3D"xsd:double"/>
> </views>
> <?xml version=3D"1.0" encoding=3D"UTF-8"?>
> <schema targetNamespace=3D'http://www.test.com/schedule'/>
> The problems are:
> 1) There is no xmlns:xsd=3D"http://www.w3.org/2001/XMLSchema", how ca=
n I =
> get this generated?
> 2) Why I can not get a complex type with 'Schedule' named? Do I have =
to =
> set more attributes? Since XSD.ecore is quit complex, I am not sure ho=
w =
> to do mapping exactly? Is there any good example?
> David
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: [QVT XSD EMF] How to get a xsd complexType from a model [message #83797 is a reply to message #83767] Fri, 06 June 2008 14:25 Go to previous message
Radek,
Comments below.
Radek Dvorak wrote:
> Hi David,
> a containment reference
> 'typeDefinitions' into the metamodel
It's good for people to look in XSDPrototypicalSchema since this class
shows pretty much an example of how to create every type of thing XSD
supports.
> the complex types should
> problem, which is NPE from
Yes, you need to decide which schema for schema namespace to use and
likely want to choose a prefix.
XSDPrototypicalSchema and XSDMainExample are good references.
> Borland QVT.
> to clients,
> output extent
> place
I can try to help on the XSD angle but I know nothing about QVT...
> Regards,
> /Radek
> <David-392.Li@MorganStanley.com> wrote:
>> Hi,
>> is as following:
>> type name := self.name;
>> The IN parameter:
>> xmlns:interop="http://ms.com/interop" domainName="interoptest"
>> schemaMetaMajorVersion="1" schemaMetaMinorVersion="4">
>> type="xsd:string"/>
>> type="xsd:double"/>
>> </views>
>> <?xml version="1.0" encoding="UTF-8"?>
>> The problems are:
>> I get this generated?
>> to set more attributes? Since XSD.ecore is quit complex, I am not
>> sure how to do mapping exactly? Is there any good example?
>> David
Previous Topic:[ATL] problem with with xmi output
Next Topic:[ATL] Generate Output Elements at runtime/dynamically
Current Time: Mon Dec 09 18:21:37 GMT 2019
Powered by FUDForum. Page generated in 0.01458 seconds
