Home » Archived » M2M (model-to-model transformation) » [QVT] Call QVT from Java code/command line
[QVT] Call QVT from Java code/command line [message #83679] Wed, 04 June 2008 14:18 Go to next message
Originally posted by: David-392.Li.MorganStanley.com
Another question :-) for QVT
Is there any way that we can call call QVT from java code? Even further,
if we can, can we get the root (pointer) for the output model instance (in
memory), not a file?
Thanks.
David
Re: [QVT] Call QVT from Java code/command line [message #83694 is a reply to message #83679] Wed, 04 June 2008 14:44 Go to previous message
Sergey Boyko is currently offline Sergey BoykoFriend
Hi David,
Java API for transformation launching is
org.eclipse.m2m.qvt.oml.runtime.util.QvtoTransformationHelpe r class.
Usage examples can be found in 'org.eclipse.m2m.qvt.oml.tests' plugin.
Code snippet:
URI scriptUri = ..
List<EObject> inObjects = ..
TransfExecutionResult execResult = new
QvtoTransformationHelper(scriptUri).executeTransformation(in Objects,
Collections.<String, Object>emptyMap(), null);
Where 'scriptUri' can specify file, platform resource or bundled script
(using platform:/plugin/ form).
Transformation output extents are created in memory. Persistence is
responsibility of caller.
Sergey
David wrote:
> (in memory), not a file?
> Thanks.
> David
Previous Topic:[QVT] qvt lanuch config: transformation IN parameter: invalid source
Next Topic:[ATL] problem with with xmi output
Current Time: Mon Aug 19 22:21:05 GMT 2019
Powered by FUDForum. Page generated in 0.02542 seconds
