Home » Eclipse Projects » EGit / JGit » Staging view shows unchanged files
Staging view shows unchanged files [message #749462] Tue, 25 October 2011 04:29 Go to next message
Hi everybody,
I have a problem with the Staging View. For an unknown reason the view
sometimes shows files, that are not dirty at all and which I have not
modified. These files are listed as unstaged changes and also appear
dirty in the package explorer. The compare editor also reveals that the
files are not changed. Often it happens that in the case “Replace with
File in Git index” does not do anything. The file stays marked dirty.
Anyone else facing the same problem or has an idea what to do in this case?
Thanks in advance.
Martin
Re: Staging view shows unchanged files [message #749659 is a reply to message #749462] Tue, 25 October 2011 07:00 Go to previous messageGo to next message
Which version of EGit are you using here ?
Did you try with the nightly build version (we did
some fixes in JGit's git index handling recently) ?
Re: Staging view shows unchanged files [message #749889 is a reply to message #749659] Tue, 25 October 2011 09:53 Go to previous messageGo to next message
Hi Matthias,
thanks for the quick response. Additional comments inline...
Am 25.10.2011 13:00, schrieb Matthias Sohn:
I am using 1.1.0.201109151100-r
Thanks for the hint. I'll update to the nightly version and let you know
if the problem still exists.
Martin
Re: Staging view shows unchanged files [message #753345 is a reply to message #749889] Wed, 26 October 2011 05:08 Go to previous messageGo to next message
Hi Matthias,
since I've updated to the nightly build the error did not appear again.
Thanks.
Martin
Am 25.10.2011 15:53, schrieb Martin Flügge:
> Hi Matthias,
> Cheers,
> Martin
Re: Staging view shows unchanged files [message #760342 is a reply to message #753345] Thu, 01 December 2011 20:32 Go to previous messageGo to next message
Hi. I have the same problem and tried to install from the Nightly link at http://download.eclipse.org/egit/updates-nightly. I'm not 100% sure how to do it, but what I did was do Help->Install New Software->Add and added the nightly link. Then I went to Help->Check For Updates and it shows the updates, but I get this message below. This seems to indicate that I can't have two versions of the Git Team Provider installed. I also tried install new software and I get the same message. I also tried uninstalling the egit and jgit stuff and then installing new from the nightly site and got the same result.
Am I doing something wrong or is something amiss with the nightly update site? Thanks. Mark Dexter
Cannot complete the install because of a conflicting dependency.
Software being installed: Eclipse EGit 1.2.0.201112010521 (org.eclipse.egit.feature.group 1.2.0.201112010521)
Software currently installed: Eclipse EGit Mylyn GitHub Feature 1.1.0.201109151100-r (org.eclipse.mylyn.github.feature.feature.group 1.1.0.201109151100-r)
Only one of the following can be installed at once:
Git Team Provider UI 1.1.0.201109151100-r (org.eclipse.egit.ui 1.1.0.201109151100-r)
Git Team Provider UI 1.2.0.201112010521 (org.eclipse.egit.ui 1.2.0.201112010521)
Cannot satisfy dependency:
From: Eclipse EGit 1.2.0.201112010521 (org.eclipse.egit.feature.group 1.2.0.201112010521)
To: org.eclipse.egit.ui
From: Eclipse EGit Mylyn GitHub Feature 1.1.0.201109151100-r (org.eclipse.mylyn.github.feature.feature.group 1.1.0.201109151100-r)
To: org.eclipse.mylyn.github.ui [1.1.0.201109151100-r]
From: Mylyn GitHub Connector UI 1.1.0.201109151100-r (org.eclipse.mylyn.github.ui 1.1.0.201109151100-r)
To: package org.eclipse.egit.ui [1.1.0,1.2.0)
Re: Staging view shows unchanged files [message #761864 is a reply to message #760342] Wed, 07 December 2011 02:53 Go to previous message
The Github connector has a different p2 repository. Since you installed Github connector 1.1 this still needs JGit 1.1 but you try to update to EGit 1.2 which requires JGit 1.2. Try also adding Github connector's nightly p2 repository http://download.eclipse.org/egit/github/updates-nightly and then retry to update.
Previous Topic:How to configure default merge strategy?
Next Topic:support for lightweight tags?
Current Time: Fri Jul 11 05:52:39 EDT 2025
Powered by FUDForum. Page generated in 0.04821 seconds
