Home » Language IDEs » C / C++ IDE (CDT) » Eclipse CDT stack overflow problem,need help.
Eclipse CDT stack overflow problem,need help. [message #747256] Mon, 24 October 2011 01:29 Go to next message
igoat is currently offline igoatFriend
Hello everyone, I started using Eclipse CDT (with MinGW on Windows) recently.
I need some very large arrays in my project.
As a result, stack overflow occurred.
In VC6.0, I used to increase the "stack allocation" amount in project->settings->link->output->stack allocation when this happened.
So where do I change the settings in Eclipse? Thanks a lot.
ps: I know there is a way to avoid this. Just use the "new" command to create large arrays and no stack overflow would happen. But I really want to know where I can increase the default stack amount in Eclipse.
Thanks again.
Re: Eclipse CDT stack overflow problem,need help. [message #749517 is a reply to message #747256] Tue, 25 October 2011 09:09 Go to previous messageGo to next message
Axel Mueller is currently offline Axel MuellerFriend
Google for "mingw stack size" gave me this.
http://www.allegro.cc/forums/thread/602743
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: Eclipse CDT stack overflow problem,need help. [message #749822 is a reply to message #749517] Tue, 25 October 2011 13:12 Go to previous messageGo to next message
Yeah, I know the command "gcc -Wl,--stack,2097152 XXX.c" would work.
But that was in CMD, I wonder whether there's a way to set the stack size in Eclipse (just like in VC6.0).
But thanks anyway.
Re: Eclipse CDT stack overflow problem,need help. [message #751796 is a reply to message #749822] Wed, 26 October 2011 06:59 Go to previous messageGo to next message
igoat wrote on Tue, 25 October 2011 15:12
But thanks anyway.
These are linker options. You can set them in Eclipse in Project Properties->C/C++Build->Settings
Before you ask
- search this forum
- google
Re: Eclipse CDT stack overflow problem,need help. [message #752371 is a reply to message #751796] Wed, 26 October 2011 11:19 Go to previous messageGo to next message
Oh, I found it.
In Project Properties->C/C++Build->Settings->Tool Settings->MinGW C++ Linker, I found there's a text box called "command" with initially "g++" in it.
So I should just change it into someting like "g++ -Wl,--stack,0xFFFFFF" and all the stack overflow problem can be solved?
Re: Eclipse CDT stack overflow problem,need help. [message #753630 is a reply to message #752371] Fri, 28 October 2011 07:05 Go to previous message
igoat wrote on Wed, 26 October 2011 13:19
Oh, I found it.
Yes, but it's better to leave the "command" untouched and add the options to the "Miscellaneous" field of the linker.
Before you ask
- search this forum
- google
Previous Topic:building with Microsoft Visual C++ toolchain (stderr?)
Next Topic:Debug facilities documetation
Current Time: Sun Dec 08 23:10:38 GMT 2024
Powered by FUDForum. Page generated in 0.03383 seconds
