Home » Archived » M2M (model-to-model transformation) » ATL: reserved keyword name clash
ATL: reserved keyword name clash [message #82701] Thu, 29 May 2008 19:02 Go to next message
Originally posted by: min.kong.morganstanley.com
In my input metamodel called "model", I have oclTypes with names:
"Integer", "Boolean", "String".
In a rule that I want to execute, I have, for instance:
if (self.oclIsKindOf(model!Integer))....
This line is invalid, because ATL doesn't consider modx!Integer a valid
oclType NAME, as "Integer" is a reserved keyword.
How should one get around problem like this, where in a metamodel, some
oclType names clash with ATL reserved keywords?
Min
Re: ATL: reserved keyword name clash [message #82802 is a reply to message #82701] Fri, 30 May 2008 07:35 Go to previous messageGo to next message
Originally posted by: r.c.ladan.tue.nl
Min wrote:
The easiest solution would be to change the metamodel, if that is possible.
Rene
Re: ATL: reserved keyword name clash [message #82851 is a reply to message #82802] Fri, 30 May 2008 08:35 Go to previous messageGo to next message
William Piers is currently offline William PiersFriend
There is another workaround you can try :
model!"Integer" instead of model!Integer
William
Rene Ladan a écrit :
> Min wrote:
>> Hi,
>> valid oclType NAME, as "Integer" is a reserved keyword.
>> some oclType names clash with ATL reserved keywords?
> Rene
Re: ATL: reserved keyword name clash [message #82971 is a reply to message #82851] Fri, 30 May 2008 14:14 Go to previous message
Double-quote works. Thanks!
Previous Topic:[ATL] exporting plugin doesn't work
Next Topic:[ATL XSD EMF]: How to convert a xsd schema file to XMI formatted file
Current Time: Mon Sep 23 15:16:10 GMT 2019
Powered by FUDForum. Page generated in 0.01968 seconds
