Home » Archived » EPP » Downloads page is confusing - questions and suggestions
Downloads page is confusing - questions and suggestions [message #7405] Thu, 21 February 2008 00:14 Go to next message
Kevin McGuire is currently offline Kevin McGuireFriend
Hi guys,
I'd like to be a good sport and try out the EPP projects because I think
they're a great idea. But I find the EPP downloads page
http://www.eclipse.org/epp/download.php
confusing and I couldn't actually download what I was expecting I could.
Some comments:
1) Should be organized by project:
The reason that I went to this page is not that I care about every EPP,
but that I care about a particular one. In this case, I was referred
here by the webtools 3.4 M5 page
http://download.eclipse.org/webtools/downloads/drops/R3.0/S- 3.0M5-20080218021547/
that asks if folks could please try out the EPP project occassionally.
The resulting EPP page thus confused me initially because I was
confronted with a table with build IDs along the top. I'd suggest that
there be a different build/download page for each packaging project to
focus on the packaging the person cares about - less overwhealming and I
could've been linked to the right spot from the webtools page.
2) Couldn't find the download:
If I click in the table on the topmost "Success" for say JEE, or any of
the other successes, I get what appears to be the build result script.
Where's the actual download?
3) Missing milestone granularity:
I really don't want to download a nightly build, what I'd like to
download is something that represents a given milestone of the contained
projects, just like I would for those individual projects. That way
there's at least a chance that it'll work, and there's something known
to log bugs against. But the table only shows the last four autobuilds
that only takes me back two days, and I didn't see an archive.
So in total the page was a complete failure for me, which is a shame.
The more we can increase the consumability of this page, the more we can
increase use of the packaging projects prior to GA, which seems a good
thing.
Kevin
Re: Downloads page is confusing - questions and suggestions [message #7416 is a reply to message #7405] Thu, 21 February 2008 16:57 Go to previous messageGo to next message
Originally posted by: mknauer.innoopract.com
Hi Kevin,
that's what I like to hear... in fact, these are the first comments on those
download pages. Well, I would have preferred something like... hey,
everything looks pretty good. But at least there are many suggestions on
how to improve the pages. Thanks.
See my comments in the text below.
Markus
Kevin McGuire wrote:
> Hi guys,
> Some comments:
Cool.
I didn't know that they already have a link to the EPP pages.
Well, my thoughts when I created that page were quite different. I wanted to
create a page which allows to see the build status (red/green) at a first
glance.
=> I will talk with the webtools people and see what we can do. At least we
should clarify the meaning of this 'nightly build page' and the 'milestone
release page' (www.eclipse.org/epp/ganymede.php)
Correct. I knew that before, but I had no time to change that in the scripts
that re-generate the page content after every build.
The download itself is on a separate download page that is linked from the
build id. I have to admit that this is not really intuitive ;-)
Yepp. You are right again - this is not clear on this page. As a quick fix
I've added a note on the top of that page that points to a location with
the 'stable' Ganymede milestone releases.
Let's try to change this!
> thing.
> Cheers,
> Kevin
Thanks again for the comments. I'll work on an improvement, but let us know
if you have more suggestions.
Markus
Re: Downloads page is confusing - questions and suggestions [message #7427 is a reply to message #7416] Thu, 21 February 2008 18:51 Go to previous messageGo to next message
Hi Markus,
Thanks for the reply. I do think the packagings are the way to go so am
happy to provide feedback and ideas. I want to see this stuff successful!
In your reply you pointed me at the milestone page, which I didn't know
existed. This is really what I was looking for, so we're actually close!
Some comments/suggestions:
1) I never found that milestone page. You've added the link from the
downloads to the milestone page and that would've solved it for me. It
could also be added to the "Important Links" list on the left hand side.
It may need to be sprinkled in other locations (e.g. see #3 and #4).
2) The URLs are a bit misleading because the daily build page is called
"\downloads" so I was expecting to find everything there (or rather,
didn't believe that another page existed).
3) As you noted, other projects should point to the milestone page.
This should be promoted as the "public" entry point, with the current
downloads (daily) page providing build health feedback to the teams.
4) On the main EPP page (http://www.eclipse.org/epp/), the "Downloads"
link in the left hand side (dark blue nav list) points to the daily
builds. I'd suggest it point to the milestones page instead, with the
the milestone page having a link to the daily builds. Again, first stop
for consumers should be milestone so this page should be promoted.
5) The main Eclipse downloads page (http://www.eclipse.org/downloads/)
gives all the Europa packages but I couldn't find a link to the current
milestones. But then, maybe you don't want to do that, with the idea of
splitting "consumer level" products from "developer testing" milestone
builds. Dunno. This split is something that we've never properly
established in Eclipse. Mind you, I think the great opportunity for the
packaging project is exactly around making this division clearer.
Best Regards,
Kevin McGuire
Markus Knauer wrote:
> Hi Kevin,
> Markus
>> Hi guys,
>> Some comments:
> Cool.
> glance.
>> thing.
>> Cheers,
>> Kevin
> Markus
Re: Downloads page is confusing - questions and suggestions [message #7438 is a reply to message #7427] Thu, 21 February 2008 22:16 Go to previous messageGo to next message
Hi Kevin,
as a first approach, I've created 3 categories: release, milestone, nightly
builds. These are linked from the main EPP page http://www.eclipse.org/epp.
All 3 pages contain links to the other categories: The main eclipse.org
download page lists the Ganymede Milestone packages in the top right
corner, the EPP milestone and EPP nightly build pages contain links to each
other.
And last but not least the menu on the left is pointing to the milestone and
nightly builds.
At this point, I cannot change the naming too much, because these pages are
linked from many places.
Stay tuned (and send comments), there will be more changes in the next
weeks.
Markus
> Hi Markus,
> Best Regards,
> Kevin McGuire
>> Hi Kevin,
>> those download pages. Well, I would have preferred something like... hey,
>> Markus
>>> Hi guys,
>>> Some comments:
>> Cool.
>> to create a page which allows to see the build status (red/green) at a
>> first glance.
>> we should clarify the meaning of this 'nightly build page' and the
>> 'milestone release page' (www.eclipse.org/epp/ganymede.php)
>> scripts that re-generate the page content after every build.
>> the build id. I have to admit that this is not really intuitive ;-)
>> fix I've added a note on the top of that page that points to a location
>> with the 'stable' Ganymede milestone releases.
>>> thing.
>>> Cheers,
>>> Kevin
>> know if you have more suggestions.
>> Markus
Re: Downloads page is confusing - questions and suggestions [message #7450 is a reply to message #7438] Thu, 21 February 2008 22:45 Go to previous message
Hi Markus,
Great! Will keep an eye out for additional changes (not that I have
opportunity to but I will try to remember to check back).
Kevin
PS. As I reread my suggestions below I used a lot of "should's".
Seemed stronger than I intended! Oops! Just trying to be helpful :)
> Hi Kevin,
> other.
> nightly builds.
> weeks.
> Thanks
> Markus
>> Hi Markus,
>> Best Regards,
>> Kevin McGuire
>>> Hi Kevin,
>>> Markus
>>>> Hi guys,
>>>> Some comments:
>>> Cool.
>>> first glance.
>>>> thing.
>>>> Cheers,
>>>> Kevin
>>> Markus
Re: Downloads page is confusing - questions and suggestions [message #576087 is a reply to message #7405] Thu, 21 February 2008 16:57 Go to previous message
Markus Knauer is currently offline Markus KnauerFriend
Hi Kevin,
Markus
> Hi guys,
> Some comments:
Cool.
glance.
> thing.
> Cheers,
> Kevin
Markus
Twitter: @mknauer23 and @EclipseRAP
Re: Downloads page is confusing - questions and suggestions [message #576107 is a reply to message #7416] Thu, 21 February 2008 18:51 Go to previous message
Hi Markus,
Best Regards,
Kevin McGuire
> Hi Kevin,
> Markus
>> Hi guys,
>> Some comments:
> Cool.
> glance.
>> thing.
>> Cheers,
>> Kevin
> Markus
Re: Downloads page is confusing - questions and suggestions [message #576148 is a reply to message #7427] Thu, 21 February 2008 22:16 Go to previous message
Hi Kevin,
other.
nightly builds.
weeks.
Markus
> Hi Markus,
> Best Regards,
> Kevin McGuire
>> Hi Kevin,
>> Markus
>>> Hi guys,
>>> Some comments:
>> Cool.
>> first glance.
>>> thing.
>>> Cheers,
>>> Kevin
>> Markus
Re: Downloads page is confusing - questions and suggestions [message #576180 is a reply to message #7438] Thu, 21 February 2008 22:45 Go to previous message
Hi Markus,
Kevin
> Hi Kevin,
> other.
> nightly builds.
> weeks.
> Thanks
> Markus
>> Hi Markus,
>> Best Regards,
>> Kevin McGuire
>>> Hi Kevin,
>>> Markus
>>>> Hi guys,
>>>> Some comments:
>>> Cool.
>>> first glance.
>>>> thing.
>>>> Cheers,
>>>> Kevin
>>> Markus
Previous Topic:Downloads page is confusing - questions and suggestions
Next Topic:Custom distros for private use?
Current Time: Sun Jul 25 14:13:58 GMT 2021
Powered by FUDForum. Page generated in 0.01862 seconds
