IMP (with LPG) on OS X [message #7383] |
Fri, 28 September 2007 11:16 |
Originally posted by: sven.efftinge.de
we at openArchitectureWare (and M2T, MWE as well) are very interested in
(and excited about :-)) IMP. We work on frameworks for DSLs as well as
on languages for model2model transformation, code generation and
validation. So the abstractions provided by IMP might be very useful here.
I'm currently trying the release from sourceforge under OS X 10.4.
Unfortunately the LPG builder doesn't work (NPE in
org.eclipse.imp.lpg.builder.LPGBuilder.isSourceFile(LPGBuild er.java:96))
In addition I'm not able to open the preferences for LPG
(IllegalArgumentException "Unable to find LPG executable at
lpgexe/lpg-macosx_x86 in bundle lpg.runtime").
Did I miss something or is it a bug?
Or is it that OS X is not supported?
Sven
Re: IMP (with LPG) on OS X [message #7456 is a reply to message #7383] |
Tue, 02 October 2007 17:41 |
Robert M. Fuhrer Messages: 294 Registered: July 2009 |
Sven Efftinge wrote:
Great!
It looks like a little of both. I.e. a bug, and not supported, that is. :-)
We only recently got some Macs here, so some of us are just starting to run on
that platform. There are a couple of missing pieces, like the binary for the LPG
parser generator, as you discovered. We have built a MacOS X binary for LPG, and
we'll add that to the LPG plugin soon.
In the meantime, you can get the LPG source from sourceforge and compile it with
gcc (I think either v3 or v4 should work fine). Then copy it into the
lpg.runtime.java/lpgexe
folder inside the 'plugins' folder of your Eclipse installation. The binary should
be named 'lpg-macosx_x86', as the error message indicates.
As for the NPE in the builder, we'll have to look into that.
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IMP Team Lead (http://eclipse-imp.sourceforge.net)
X10: Productivity for High-Performance Parallel Programming (http://x10.sf.net)
Re: IMP (with LPG) on OS X [message #566870 is a reply to message #7383] |
Great!
-- Bob
Robert M. Fuhrer
FUDForum. Page generated in 0.02868 seconds
