Home » Archived » M2M (model-to-model transformation) » [ATL] How to Compile a *.atl to .*asm via Java Code?
[ATL] How to Compile a *.atl to .*asm via Java Code? [message #82225] Mon, 26 May 2008 20:47 Go to next message
Originally posted by: melycat.gmail.com
Hello
How to Compile an *.atl to .*asm via Java Code?
I've tried instantiate an AtlCompile, however I can't to call the method
"compile".
This method needs two arguments: an InputStream class and IFile class.
How can I do this?
best regards.
Melyssa.
Re: [ATL] How to Compile a *.atl to .*asm via Java Code? [message #82251 is a reply to message #82225] Mon, 26 May 2008 23:14 Go to previous messageGo to next message
Originally posted by: freddy.allilaire.univ-nantes.fr
--------------030603020000030703030308
Hi Melyssa,
I advised you to take a look to the "org.eclipse.m2m.atl.adt.builder"
plugin. This will show you how the ATL compiler is used in ATL toolkit:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.adt.builder/src /org/eclipse/m2m/atl/adt/builder/AtlBuildVisitor.java?revisi on=1.8&root=Modeling_Project&view=markup
HTH
Freddy
OBEO
Melyssa a
Re: [ATL] How to Compile a *.atl to .*asm via Java Code? [message #82385 is a reply to message #82251] Tue, 27 May 2008 18:46 Go to previous message
Hello Freddy! Thanks Very Much!
best regards.
Melyssa
Previous Topic:no KM3 in ATL
Next Topic:[ATL] Material on ATL programming regardiing UML
Current Time: Mon Jun 24 10:48:01 GMT 2019
Powered by FUDForum. Page generated in 0.01839 seconds
